Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Documents
Models
315.17504
Background
The Craftsman Router 315.175040, along with its sister models 315.175050 and 315.175060, is a series of electric routers used for woodworking tasks. These routers, produced by Sears, Roebuck and Co, are equipped with a motor that ranges from 1.5 to 2 horsepower depending on the model. All models use a 1/4 inch collet.
The Craftsman Router is designed for handheld use or can be mounted in a router table. It stands out for its variable speed control feature available in models 315.175050 and 315.175060, which allows the user to adjust the speed according to the bit sizes and materials being used. The routers also have a depth adjustment ring with a micro-adjust knob, and model 315.175060 comes with a dust collection bag. The routers use a 1/4 inch shank router bit, which is a standard in the industry. The depth adjustment feature varies with each model, with a range of 0 to 2 inches.
Technical Specifications
  • Model Number: 315.175040
  • Product Type: Router
  • Motor power: 1.5 HP
  • Speed: 25,000 rpm
  • Collet size: 1/4 inch
  • Adjustable depth: 0 to 1-1/2 inches
  • Weight: 8 to 9 pounds
  • Double insulation: Yes
  • Spindle lock: Yes
  • Soft start motor: Yes
  • Clear sub-base: Yes
  • Variable speed control: No
  • Dust collection with bag: No
  • Designed for: Handheld use or mounting in a router table
Warranty
The Craftsman Router 315.175040, along with models 315.175050 and 315.175060, come with a 1-year warranty provided by Sears, Roebuck and Co. This warranty typically covers any defects in the materials or workmanship of the product from the date of purchase. If the router fails due to a manufacturing defect within this period, the warranty should cover the cost of repair or replacement. To claim the warranty, you would generally need to provide proof of purchase, such as a sales receipt, and contact Sears' customer service. However, the specific terms and conditions, as well as the claiming process, may vary, so it's recommended to check the warranty details provided with the product or consult Sears directly.
Craftsman 315.175040 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 49
All Time: 2,166
