Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Models
315.17491
Background
The Craftsman Router 315.17491 is a portable, handheld power tool, designed and manufactured by Diehl Manufacturing Co. for Sears under the Craftsman brand. The router is commonly used in woodworking applications such as cutting, trimming, and shaping wood and other materials.
The Craftsman 315.17491 router is equipped with a 10-amp motor that allows the bit to spin at a maximum speed of 27,000 RPM. It carries a 1-3/4 peak horsepower rating, suggesting its capacity to undertake edge forming and light-duty woodworking tasks in materials such as softwoods and medium-density fiberboards. The router comes with a fixed base made from plastic, while the motor housing is constructed from aluminum. The Craftsman 315.17491 router also includes a 1/4 inch and 1/2 inch collet to accommodate different shank size bits and a 6-foot power cord for mobility. It also accepts industry standard template guides, making it compatible with various jigs and patterns.
Technical Specifications
  • Motor: 10 amp, 1-3/4 peak horsepower
  • Variable speed: 10,000 - 27,000 RPM
  • Collet sizes: 1/4 inch, 1/2 inch
  • Base: Plastic fixed base
  • Bit capacity: 1-3/4 inch
  • Weight: 8 lbs
  • Power cord length: 6 foot
  • Construction: Aluminum motor housing
  • Bit change mechanism: Spindle lock for easy bit changes
  • Template guide compatibility: Accepts industry standard template guides
Warranty
The Craftsman Router 315.17491 comes with a manufacturer's warranty that lasts for 3 years. This limited warranty specifically covers any defects in both materials and workmanship that may occur under normal use. However, it's important to note that wear parts such as brushes and switches are not included in the warranty coverage. Additionally, any damage that results from misuse or improper alterations will render the warranty void.
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 49
All Time: 1,085
