No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
315.17534
Background
The Craftsman Rotary Grinder 315.175340 is a portable power tool produced for Sears under the Craftsman brand. This particular model was made by Diehl Manufacturing Co., before the production was handed over to Ryobi. The rotary grinder is designed for a variety of uses, mainly for shaping, hollowing, grooving, slotting, and making ornamental patterns in wood.
The Craftsman Rotary Grinder 315.175340 operates on a 120V 60Hz AC motor, and provides a no-load speed of 25,000 rpm. The model is double insulated, negating the need for a grounding power cord. A unique feature is its conveniently located toggle on/off switch. The rotary grinder has a spindle lock for securing the spindle during bit changes and base installation. It also comes with a removable clear plastic chip guard and an adjustable depth stop with depth scale. The router accepts template guides and other common router accessories.
Technical Specifications
  • Model Number: 315.175340
  • Product: Craftsman Rotary Grinder
  • Power Source: 120V 60Hz AC, 9.5A
  • Horsepower: 2 hp
  • No Load Speed: 25,000 rpm
  • Collet Size: 1/4 in
  • Plunge Depth Capacity: 2 in
  • Fixed/D-handle Base Depth Capacity: 1-1/2 in
  • Power Cord Length: 10 ft
  • Weight: 5 lb 6 oz
Warranty
The Craftsman Rotary Grinder 315.175340 comes with a full 1 year warranty provided by Sears. This warranty covers the repair of the tool in case of any failures within a year from the date of purchase. To claim the warranty, the faulty tool should be returned to any Sears store where it will be repaired free of charge. However, it's important to note that for commercial or rental use, the warranty coverage is shorter, lasting only 90 days from the purchase date.
Craftsman 315.175340 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 35
All Time: 742
