No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
315.10122
Background
The Craftsman 315.101221 is a corded electric power tool produced by Diehl Manufacturing Company for Sears under the Craftsman brand. This tool is primarily designed for drilling into a variety of materials, including wood, plastic, ceramic, fiberglass, laminates, and metal. Additionally, it can also function as a screwdriver when paired with screwdriver bits and can be used to mix paints.
The drill is equipped with a 3/8 inch chuck and a 1/3 horsepower motor, which can be powered by a 120V AC power source. It features a variable speed trigger control, which allows the user to adjust the drill speed and torque depending on the task at hand. Moreover, the drill has a reversible direction feature, making it versatile for different drilling requirements. The device also includes a lock-on button that enables continuous drilling and has an on-board storage for the chuck key. The drill's speed ranges from 0 to 1300 RPM, its overall length is 7.5 inches, and it has a net weight of 3.7 lbs.
Technical Specifications
  • Model Number: 315.101221
  • Product Type: Reversible Drill
  • Power Source: 120V AC, 60Hz
  • Amperage: 3 Amps
  • Motor Power: 1/3 HP
  • Chuck Capacity: 3/8 inch
  • No Load Speed: 0-1300 RPM
  • Reversibility: Yes
  • Speed Control: Variable speed trigger
  • Overall Length: 7.5 inches
  • Net Weight: 3.7 lbs
Warranty
The Craftsman 315.101221 comes with a comprehensive one-year warranty. This warranty covers the drill should it fail to perform satisfactorily within the first year after purchase. In such a case, the drill can be returned to any Sears store or Sears service center across the United States, where it will be replaced free of charge. However, it is important to note that the warranty period shortens to 90 days if the drill is being used for commercial purposes or if it is rented out. The warranty provides specific legal rights that might change depending on the state.
Craftsman 315.101221 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 7
Past 7 Days: 8
Past 30 Days: 21
All Time: 290
