No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
919.79601
Background
The Craftsman Pressure Washer 919.79601 is a product designed for general residential cleaning tasks. This model is gas-powered and uses a 270cc Craftsman OHV 4-cycle engine to produce the required water pressure. The pressure washer can generate a maximum of 3100 PSI of water pressure with a water flow rate of 2.4 GPM. The machine comes with a 25-foot high pressure hose, a spray gun, and variable nozzle tips.
The pressure washer also includes an integrated detergent tank for cleaning solutions. It is built on a steel cart with two 10-inch pneumatic tires, which aids in mobility. Additionally, it features an auto-start and stop fuel valve, a brass garden hose connector, and a thermal relief valve. The Craftsman Pressure Washer 919.79601 is typically used for various cleaning tasks around the house, such as washing siding, cars, grills, patio furniture, and other outdoor items.
Technical Specifications
  • Model Number: 919.79601
  • Product: Craftsman Pressure Washer
  • Product Type: Pressure Washer
  • Power Source: 270cc 4-cycle engine
  • Maximum Pressure: 3100 PSI
  • Water Flow Rate: 2.4 GPM
  • High Pressure Hose Length: 25 ft
  • Detergent Tank Capacity: 1 gal
  • Fuel Tank Capacity: 1.1 gal
  • Pump Type: Axial cam
  • Power: Gasoline
  • Mobility: Wheeled base
  • Power Cord Length: 30 ft
  • Weight: Approximately 100 lbs
  • Additional Features: Auto-start and stop fuel valve, brass garden hose connector, thermal relief valve
  • Use: Residential
Warranty
The Craftsman Pressure Washer 919.79601 comes with a limited warranty provided by Craftsman. The warranty period is 2 years for the pump and 90 days for other components of the pressure washer. This warranty covers defects in materials or workmanship that occur during normal use within the specified warranty period. In order to claim the warranty, you should reach out to Craftsman's customer service with valid proof of purchase and details about the issue you are experiencing. Please note that the warranty does not cover any damage or issues that occur due to improper use or maintenance.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 18
All Time: 209
