No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
919.76235, 919.762350
Background
The Craftsman Pressure Washer 919.762350 is a pressure washer manufactured by Ingersoll Rand for Sears under the Craftsman brand. This model is designed with a 6.0 horsepower Briggs & Stratton engine and capable of outputting a maximum pressure of 2350 PSI at a flow rate of 2.2 GPM. The pressure washer is fueled by gasoline and has a fuel tank capacity of 1.5 quarts. It also requires 20 oz of SAE 30 weight oil for operation. The dimensions of the pressure washer are approximately 19 x 19 x 34 inches and it weighs around 60 lbs.
This model includes a triplex plunger pump with ceramic pistons, an adjustable pressure setting and an adjustable spray nozzle that allows for high and low pressure settings as well as fan and stream patterns. It also features an onboard detergent tank for cleaning solutions, a 25-foot high-pressure hose, a garden hose connector, and wheels for portability. The pressure washer operates by adding gasoline and engine oil as required, connecting a garden hose to the water inlet and a high-pressure hose to the pump outlet. The engine is started by pulling the recoil starter and the spray gun is unlocked to begin spraying. The nozzle can be adjusted for desired pressure and pattern, and a detergent suction tube can be used to apply cleaning chemicals. Regular maintenance includes changing engine oil, checking and cleaning the water inlet screen, inspecting the high pressure hose, cleaning the nozzle when necessary, and draining gasoline and adding fuel stabilizer for long term storage.
Technical Specifications
  • Engine: 6.0 HP Briggs & Stratton model 121602-0206-E1
  • Pump: Triplex plunger pump
  • Pressure: 2350 PSI
  • Flow Rate: 2.2 GPM
  • Cleaning Units: 5170 (PSI x GPM)
  • Power Source: Gasoline
  • Fuel Tank Capacity: 1.5 quarts
  • Oil Capacity: 20 oz SAE 30 weight oil
  • Dimensions: Approximately 19 x 19 x 34 in
  • Weight: Approximately 60 lbs
Craftsman 919.762350 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 38
All Time: 815
