2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.9884
Background
The Craftsman 2500 PSI Pressure Washer (Model 580.988400) is a gas-powered machine designed to clean various surfaces. It is equipped with a 190 cc Briggs & Stratton engine and can produce up to 2500 PSI (pounds per square inch) of water pressure, with a flow rate of 2.0-2.3 gallons per minute. The pressure washer is powered by gasoline and has a fuel tank capacity of 1.6 quarts.
The machine comes with a variety of features including a metal pump, a 25 ft high pressure hose, and a detergent siphon tube for applying cleaning solutions. It also has three quick connect spray tips that allow for adaptation to different cleaning requirements. The pressure washer has pneumatic tires and a steel tube frame for stability, and an automatic cool down system that cycles water through the pump when the temperature exceeds 125°F. Regular maintenance is recommended to ensure the performance and longevity of the pressure washer.
Technical Specifications
  • Model Number: 580.988400
  • Product: Craftsman 2500 PSI Pressure Washer
  • Maximum pressure: 2500 PSI
  • Maximum flow rate: 2.3 GPM
  • Detergent system: Use detergent siphon tube
  • Engine: Briggs & Stratton 126M02-0342-F1
  • Engine displacement: 190 cc
  • Fuel tank capacity: 1.6 quarts
  • Power source: Gasoline
  • Dimensions: approx. 18" x 19" x 34"
  • Weight: approx. 60 lbs
Craftsman 580.988400 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 34
All Time: 375
