Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.768341
Background
The Craftsman 580.768341 is a pressure washer developed by Sears, Roebuck and Co, primarily designed for residential cleaning tasks. It operates on a 5.5 horsepower Honda GCV160 engine and employs an axial cam pump. The machine is capable of generating a water pressure of up to 2400 PSI (pounds per square inch) with a flow rate of 2.2 GPM (gallons per minute). Its fuel tank can accommodate 1.2 quarts of fuel.
This pressure washer comes with an adjustable pressure nozzle, a 25-foot high-pressure hose, and a garden hose connector. Additionally, it is fitted with a detergent injection system and a hose reel on board. The device is designed to be easily portable with the help of pneumatic tires and a pull handle. It also includes an external container for detergent and various nozzle tips for different types of cleaning. The Craftsman 580.768341 operates with a displacement of 160 cc and measures 17" x 17" x 34" in dimensions. It weighs approximately 60 lbs. Regular maintenance should be performed for optimal functionality, such as checking and cleaning the water inlet screen, checking the high-pressure hose for leaks, and changing the engine oil and air filter at the recommended intervals.
Technical Specifications
  • Model Number: 580.768341
  • Product Type: Pressure Washer
  • Engine: 5.5 HP Honda GCV160 4-stroke overhead valve air-cooled
  • Engine Displacement: 160 cc
  • Fuel Tank Capacity: 1.2 quarts
  • Pump Type: Axial cam pump with thermal relief valve
  • Pump Pressure: Up to 2400 PSI
  • Water Flow Rate: 2.2 GPM
  • High Pressure Hose Length: 25 ft
  • Detergent Tank: External container
  • Nozzle Tips: 0°, 15°, 25°, 40°
  • Dimensions: 17" x 17" x 34"
  • Weight: 60 lbs
Warranty
The Craftsman 580.768341 pressure washer comes with a one-year limited warranty that covers defects in materials and workmanship. The warranty period varies depending on the usage of the product: it is valid for one year from the date of purchase for general use, 90 days for commercial use, and 30 days for rental use. However, the warranty does not cover damage due to improper use, abuse, or lack of recommended maintenance.
Craftsman 580.768341 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 336
