No Image
This wiki is missing a device image. Help improve this page by uploading one!
5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.768332
Background
The Craftsman Pressure Washer 580.768332 is a gas-operated device designed for cleaning various surfaces with high-pressure water. The product is equipped with a Briggs & Stratton Intek engine which has a horsepower of 6.0. The device has the ability to generate a maximum pressure of 2,400 PSI (pounds per square inch) and has a flow rate of 2.2 GPM (gallons per minute). Among its other features are a detergent tank, a 30 ft high-pressure hose, and various nozzle tips (0°, 15°, 40° and low pressure for detergent application). The pressure washer's pump is an axial cam direct drive and it has a fuel tank capacity of 1.6 quarts. The device weighs 75 lbs.
The Craftsman Pressure Washer 580.768332 is intended for various cleaning tasks. It can be employed for cleaning decks, patios, driveways, vehicles, and more. To operate, the user needs to add engine oil and gasoline, connect the high-pressure hose, attach the garden hose, and start the engine. The detergent feature is used by installing the low-pressure black nozzle tip and filling the detergent tank. The pressure washer should be maintained according to the manufacturer's schedule including regular checks of the water inlet screen, high-pressure hose, detergent hose, spray gun/nozzles, and engine oil, and servicing of the air cleaner, spark plug, and spark arrester. Special measures such as addition of RV antifreeze and fuel stabilizer, draining oil, and disconnecting the spark plug wire are recommended for winter and long-term storage.
Technical Specifications
  • Model Number: 580.768332
  • Product Type: Pressure Washer
  • Manufacturer: Sears
  • Engine: 6.0 HP Briggs & Stratton Intek
  • Maximum Pressure: 2,400 PSI
  • Flow Rate: 2.2 GPM
  • High Pressure Hose Length: 30 ft
  • Nozzle Tips: 0°, 15°, 40° and low pressure
  • Pump Type: Axial cam direct drive
  • Fuel Tank Capacity: 1.6 quarts
  • Weight: 75 lbs
Warranty
The Craftsman Pressure Washer 580.768332 comes with a limited warranty that offers coverage for a period of 1 year for consumers and 90 days for commercial use, effective from the purchase date. In addition, the engine emission control system of the device is specifically covered under a separate 2-year warranty. The warranty coverage includes defects in materials and workmanship, provided that the device has been operated and maintained in accordance with the instructions given in the owner's manual. However, it is important to note that the warranty does not extend to any damage resulting from improper use or lack of required maintenance.
Craftsman 580.768332 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 25
All Time: 398
