Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.76745
Background
The Craftsman Pressure Washer 580.767450 is a gasoline-powered device designed to deliver a high-pressure water spray. Manufactured by Goldstar for Sears, it is designed to be portable, making it suited to a variety of outdoor cleaning tasks. The washer is equipped with a Briggs & Stratton engine with a 6.75 horsepower rating. It can achieve a pressure of 2500 PSI and has a flow rate of 2.5 gallons per minute.
The Craftsman Pressure Washer 580.767450 incorporates several features to enhance its functionality and user experience. It comes with 10" pneumatic tires and a foldable handle for ease of transportation. The pressure nozzle is adjustable, offering flexibility between high and low pressure, as well as the capacity to adjust the spray pattern. It also includes a dial-a-cleaner selector knob for the mixture of chemicals in three separate reservoirs. Furthermore, it has an automatic cool down system that cools the pump if it remains untriggered for 3-5 minutes, and a hose reel for storing the high pressure hose when not in use.
Technical Specifications
  • Model Number: 580.767450
  • Product: Craftsman Pressure Washer 580.767450
  • Product Type: Pressure Washer
  • Pressure: 2500 PSI
  • Flow rate: 2.5 GPM
  • Engine: 6.75 HP Briggs & Stratton 128612
  • Fuel tank capacity: 1.6 quarts
  • Weight: 102 lbs
  • Mobility features: 10" pneumatic tires and foldable handle
  • Adjustable pressure nozzle: Slides between high and low pressure, can adjust spray pattern.
  • Detergent application: Dial-a-Cleaner selector knob allows mixing of chemicals in 3 reservoirs
  • Automatic cool down system: Thermal relief feature cools pump if not triggered for 3-5 minutes
  • Hose storage: Hose reel for storage of high pressure hose when not in use
Warranty
The Craftsman Pressure Washer 580.767450 comes with a limited warranty that lasts for a duration of 1 year. This warranty specifically covers any defects that might occur due to the materials used or the workmanship for non-commercial use. However, it's important to note that the warranty period is shorter for other types of use: it is reduced to 90 days for commercial use and just 30 days for rental use.
Craftsman 580.767450 Owners Manual
Craftsman 580.767450 6.75 HP, 2500 PSI, 2.5 GPM Pressure Washer Owner's Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 27
All Time: 555
