No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.7673
Background
The Craftsman 580.767300 is a pressure washer model produced by Sears. It utilizes a 6.5 HP Briggs & Stratton engine and an Annovi Reverberi AR triplex pump to generate up to 2400 PSI of water pressure at a flow rate of 2.2 gallons per minute. The power source for this model is a gasoline engine.
The unit includes features such as an adjustable pressure nozzle, a detergent injection system, and a 25-foot high-pressure hose. The thermal relief valve helps prevent overheating by cycling water through the pump. For storage and movement convenience, it has onboard nozzle storage, a hose reel, and 12-inch pneumatic tires. The machine's Briggs & Stratton IC overhead valve engine comes with a recoil start, a fuel capacity of 3 quarts, and a full pressure lubrication system with a spin-on oil filter. The Annovi Reverberi AR triplex pump is directly connected to the engine crankshaft and has a maximum pressure rating of 3000 PSI.
Technical Specifications
  • Model Number: 580.767300
  • Product: Craftsman Pressure Washer 580.767300
  • Product Type: Pressure Washer
  • Pressure: 2400 PSI
  • Flow Rate: 2.2 GPM
  • Engine: 6.5 HP Briggs & Stratton
  • Pump: Triplex pump
  • Power Source: Gasoline engine
  • Dimensions: approx 24 x 19 x 37 in
  • Weight: 94 lbs
  • Adjustable pressure nozzle: Yes
  • Detergent injection system: Yes
  • High pressure hose length: 25 ft
  • Hose reel: Yes
  • Thermal relief valve: Yes
  • Onboard nozzle storage: Yes
  • Wheel Size: 12 inch pneumatic tires
  • Engine fuel capacity: 3 quarts
  • Engine Oil System: Full pressure lubrication system with spin-on oil filter
  • Pump Type: Triplex axial piston pump with three plungers and built-in thermal relief valve
  • Pump Maximum Pressure Rating: 3000 PSI
  • Pump Connection: Directly to the engine crankshaft
Craftsman 580.767300 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 41
All Time: 578
