No Image
This wiki is missing a device image. Help improve this page by uploading one!
5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.767302
Background
The Craftsman Pressure Washer 580.767302 is a pressure washer produced by Craftsman. It uses a 6.5 horsepower Briggs & Stratton engine to create water pressure up to 2400 PSI at a flow rate of 2.2 gallons per minute.
The Craftsman Pressure Washer 580.767302 features an adjustable spray nozzle with high and low pressure settings. It includes a 25 ft steel-reinforced high pressure hose with an onboard reel for storage. Additionally, it has a thermal relief system to prevent pump overheating, a garden hose connector with inlet screen, a detergent siphon tube for applying cleaning chemicals, a pneumatic tires and fold-down handle for portability. The pressure washer is operated using gasoline. Its additional specifications include displacement of 12.5 cu.in, fuel capacity of 3 quarts, a high pressure hose length of 25 ft, a detergent tank of 1/2 gallon, dimensions of 17 x 19 x 34 in, and a weight of 94 lbs.
Technical Specifications
  • Model Number: 580.767302
  • Product Type: Gas-powered Pressure Washer
  • Engine: 6.5 HP Briggs & Stratton
  • Displacement: 12.5 cu.in
  • Fuel Capacity: 3 quarts
  • Pump Type: Axial cam pump
  • Pressure Capacity: Up to 2400 PSI
  • Flow Rate: 2.2 GPM
  • Power Source: Gasoline
  • High Pressure Hose Length: 25 ft
  • Detergent Tank Capacity: 1/2 gallon
  • Dimensions: 17 x 19 x 34 in
  • Weight: 94 lbs
Warranty
The Craftsman Pressure Washer 580.767302 comes with a 1-year limited warranty that covers parts and performance. It's important to note that if the pressure washer is used for commercial or rental purposes, the warranty coverage is shortened to 90 days from the date of purchase. The Briggs & Stratton engine, which is a vital component of this pressure washer, may be subject to additional warranty coverage from its respective manufacturer. To claim the warranty, the owner should contact the manufacturer or the retailer from where the product was purchased, providing them with the details of the issue along with the proof of purchase.
Craftsman 580.767302 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 25
All Time: 448
