No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.7672
Background
The Craftsman 580.767200 is a pressure washer that operates on a 5.5 horsepower Briggs & Stratton engine. It is designed to deliver a maximum pressure of 2,250 PSI and a flow rate of 2.2 gallons per minute. This pressure washer is distinguished by its fuel tank capacity of 1.6 quarts and its compatibility with different types of oil depending on the temperature conditions.
The Craftsman 580.767200 includes features such as an adjustable nozzle. This allows the user to switch between high and low pressure settings, and alter the spray pattern from a narrow stream to a wide fan pattern. A unique characteristic of this pressure washer is its detergent siphon tube that facilitates the application of cleaning chemicals by drawing directly from a detergent bottle attached to the unit. Maintenance suggestions are also provided for this pressure washer, which include checking the water inlet screen, high pressure hose, and engine oil, as well as replacing the oil, spark plug, and air filter annually.
Technical Specifications
  • Model Number: 580.767200
  • Product: Craftsman Pressure Washer
  • Engine: 5.5 HP Briggs & Stratton
  • Pressure output: 2,250 PSI
  • Flow rate: 2.2 gallons per minute
  • Fuel tank capacity: 1.6 quarts
  • Oil type: SAE 30 above 40°F, SAE 5W-30 or 10W-30 between 0°F - 40°F
  • Nozzle: Adjustable for high and low pressure, and spray pattern
  • Detergent application: Siphon tube feeding from a mounted detergent bottle
Warranty
The Craftsman 580.767200 pressure washer comes with a one-year manufacturer's warranty. This warranty is applicable to the pump and other components of the product, covering any defects that may arise due to materials or workmanship. However, it is essential to note that exclusions apply to this warranty. Wear items such as the nozzle, hose, and filters are not covered. The warranty also does not cover damage resulting from improper maintenance or storage, use of incorrect fluid or fuel types, or freezing damage. Additionally, the engine and emissions components of the washer have extra warranty coverage as mandated by the EPA and California emissions regulations. To claim the warranty, you must adhere to the manufacturer's guidelines and recommended maintenance procedures. If any defects arise under these conditions within the warranty period, you're entitled to a repair or replacement of the faulty parts.
Craftsman 580.767200 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 302
