No Image
This wiki is missing a device image. Help improve this page by uploading one!
5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.767202
Background
The Craftsman Pressure Washer 580.767202 is a gasoline-powered device produced by Sears. This pressure washer is powered by a 5.5 horsepower Briggs & Stratton engine, delivering a pressure of up to 2250 PSI at a flow rate of 2.2 GPM. The model is equipped with an adjustable nozzle that allows for a focused stream or a wide fan pattern, offering flexibility in its use. It comes with an in-line filter and an o-ring maintenance kit.
This pressure washer also features an axial cam pump with thermal relief, which automatically cools the pump when in operation for 3-5 minutes without the trigger being pulled, thereby preventing overheating. The device sits on a steel base with rubber tires for easy mobility. It includes a 33-inch steel wand for reaching higher surfaces and a 25-foot PVC hose rated for up to 3000 PSI. Maintenance of the pressure washer involves checking and cleaning the water inlet filter, flushing the pump with clean water after every use, and regularly servicing the oil, air filter, and spark plug.
Technical Specifications
  • Model Number: 580.767202
  • Product Type: Pressure Washer
  • Engine: 5.5 HP Briggs & Stratton
  • Pump: Axial cam direct drive
  • Pressure: 2250 PSI
  • Flow Rate: 2.2 GPM
  • Fuel Tank Capacity: 1.6 quarts
  • Detergent Tank: External container
  • Power Source: Gasoline
  • Dimensions: approx. 18 x 24 x 36 in.
  • Weight: approx. 74 lbs.
  • Nozzle: Adjustable with settings for high and low pressure
  • Spray Patterns: Focused stream or a fan pattern up to a 45° angle
  • Filter: In-line filter included
  • Wand: 33 inch steel wand
  • Hose: 25 foot PVC hose rated for up to 3000 PSI
  • Mobility: Two rubber tires
  • Pump Cooling: Automatic cooling if left running for 3-5 minutes without the trigger being pulled
Warranty
The Craftsman Pressure Washer 580.767202 comes with a warranty coverage for a period of time. The overall product is covered by a 1-year warranty that protects against defects and issues with craftsmanship. In addition, the pump has a separate 2-year warranty. To claim the warranty, it would generally involve contacting the manufacturer, Sears, and providing them with relevant information such as the date of purchase, proof of purchase, and details about the problem you're experiencing with your pressure washer. However, the exact process for claiming the warranty may vary, so it is recommended to refer to the product's user manual or Sears' official website for specific instructions.
Craftsman 580.767202 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 49
All Time: 740
