No Image
This wiki is missing a device image. Help improve this page by uploading one!
4 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.7671
Background
The Craftsman 580.767100 is a pressure washer designed for a range of outdoor cleaning tasks. It is powered by a gasoline engine and operates by pressurizing water to a high level before discharging it through a spray wand. The pressure washer employs a 5.0 horsepower Briggs & Stratton engine and can generate up to 2,100 PSI of water pressure at a flow rate of 2.0 gallons per minute. The engine displacement is 305cc and it has a fuel tank capacity of 1.6 quarts.
The Craftsman 580.767100 is equipped with a range of features that enhance its functionality. These include a portable cart frame with 10" pneumatic tires for easy maneuverability, a 25 ft steel braided high-pressure hose, and an adjustable spray wand with quick connect nozzles. The pressure washer also includes an onboard soap tank and injection system for applying cleaning solutions, and a thermal relief system to protect the pump from overheating. The pump is an axial cam direct drive design, capable of producing high pressures and has a brass pump head for corrosion resistance.
Technical Specifications
  • Model Number: 580.767100
  • Product: Pressure Washer
  • Manufacturer: Sears, Roebuck and Co.
  • Engine: 5.0 HP Briggs & Stratton 128802
  • Displacement: 305cc
  • Fuel Tank Capacity: 1.6 quarts
  • Pump Type: Axial cam direct drive
  • Maximum Pump Pressure: 2,100 PSI
  • Flow Rate: 2.0 GPM
  • High Pressure Hose Length: 25 ft
  • Soap Tank Capacity: 1/2 gallon
  • Weight: Approx. 60 lbs
  • Frame: Portable cart frame with 10" pneumatic tires
  • Hose: 25 ft steel braided high pressure hose
  • Spray Wand: Adjustable with quick connect nozzles
  • Soap System: Onboard soap tank and injection system
  • Thermal Relief System: Yes
  • Automatic Cool Down System: Yes
  • Engine Type: Air-cooled single cylinder 4-stroke gasoline engine with pressure lubrication and recoil start
  • Engine Power Rating: 5 horsepower at 3600 RPM
  • Carburetor: Float feed
  • Oil Type: 30W detergent oil
  • Oil Capacity: 20 fluid ounces
  • Pump Design: Three piston with ceramic plungers and reinforced thermoplastic body
  • Pump Head Material: Brass
  • Optional Accessories: 25' hose extension, rotating brush kit, hose reel, turbo nozzles, pump saver for winterization, detergent concentrates.
Warranty
The Craftsman 580.767100 Pressure Washer comes with a 1-year limited warranty. This warranty covers any defects in materials and workmanship that may occur during this period. In the event that such defects arise, customers can claim the warranty. The pump, a crucial component of the pressure washer, also carries a 1-year warranty against defects. To claim the warranty, you should contact Sears Parts Direct either through their online platform or by calling at 1-800-366-PART. Be sure to have your product details, including the model number and a description of the issue, ready when requesting warranty service.
Craftsman 580.767100 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 383
