No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.76225
Background
The Craftsman Pressure Washer 580.762250 is a portable device designed to produce high-pressure water spray. It is equipped with a 6.0 horsepower Briggs & Stratton engine and can produce up to 2250 psi of water pressure with a flow rate of 2.2 gallons per minute. Other notable features include the ability to draw water directly from a garden hose and withstand a maximum inlet temperature of 140°F. The pressure washer comes with a 25 ft high-pressure hose and a spray gun equipped with an adjustable nozzle, allowing the user to modify the pressure and spray pattern.
The operation of this pressure washer involves filling it with oil and gasoline, connecting it to a water source, attaching the high-pressure hose to the pump outlet and the spray gun, and starting the engine. The pressure and spray pattern can be adjusted using the nozzle. The device also has a mode for dispensing detergent at low pressure. Regular maintenance such as checking and cleaning the water inlet screen, inspecting the high-pressure hose, detergent hose, and filter, checking the pump and spray gun for leaks, and changing the engine oil and air filter periodically is recommended.
Technical Specifications
  • Model Number: 580.762250
  • Engine: 6.0 horsepower Briggs & Stratton
  • Displacement: 158cc
  • Max Pressure: 2250 psi
  • Flow Rate: 2.2 gallons per minute
  • Detergent Mix: Use undiluted detergent
  • Fuel Tank Capacity: 1 quart
  • Oil Capacity: 20 ounces
  • Spark Plug: Champion RJ-8C (gap 0.030 inch)
  • Dimensions: Approximately 24 x 19 x 40 inches
  • Weight: Approximately 60 pounds
  • Maximum Inlet Temperature: 140°F
  • High Pressure Hose Length: 25 feet
  • Spray Gun: Adjustable nozzle for controlling pressure and spray pattern
  • Operation: Manual start, with adjustable pressure and spray controls
  • Water Source: Can draw directly from a garden hose
Warranty
The Craftsman Pressure Washer 580.762250 comes with a limited 1 year consumer warranty. The warranty coverage is not explicitly mentioned in the provided context, but typically, such warranties cover any defects in materials or workmanship. To claim the warranty, the user would likely need to present proof of purchase and contact the manufacturer directly, although the exact claim procedure is not specified in the given text.
Craftsman 580.762250 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 237
