No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.7618
Background
The Craftsman Pressure Washer 580.761800 is a gas-powered device produced by Sears, Roebuck and Co. It is equipped with a 4.5 horsepower Briggs & Stratton engine and an axial cam pump. This combination allows the pressure washer to deliver 1.8 gallons per minute at a pressure of 1800 PSI (pounds per square inch).
The pressure washer has an adjustable spray nozzle, permitting users to alter the pressure and spray patterns. It includes an onboard detergent tank, a 25 ft steel-reinforced high pressure hose, and pneumatic tires with a fold-up handle for easier transportation. It operates by connecting a garden hose to the water inlet and the high pressure hose to the pump and spray gun. Users then turn on the water supply, engage the trigger safety lock, and start the engine by pulling the recoil cord. The nozzle can be adjusted for low pressure detergent application or high pressure rinsing.
Technical Specifications
  • Model Number: 580.761800
  • Pressure: 1800 PSI
  • Flow Rate: 1.8 GPM
  • Engine: 4.5 HP Briggs & Stratton 4-stroke
  • Fuel Type: Unleaded gasoline
  • Fuel Capacity: 1.6 quarts
  • Power Source: Recoil start
  • Pump: Axial cam pump
  • Weight: 65 lbs
  • Dimensions: 24" x 19" x 24"
  • High Pressure Hose Length: 25 ft
Warranty
The Craftsman 1800 PSI High Pressure Washer (Model 580.761800) comes with a limited warranty that lasts for a period of 1 year. This warranty covers any defects in both the materials and workmanship of the product. However, it is important to note that wear parts such as hoses, fittings, and filters which are subject to normal wear are not included in this warranty. In the case of commercial and rental use, the warranty coverage is valid for 90 days and 30 days respectively.
Craftsman 580.761800 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 31
All Time: 379
