2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.75492
Background
The Craftsman 580.754920 is a pressure washer powered by a gas engine. It is designed to emit a pressurized stream of water, with a maximum pressure of 2800 PSI at 2.1 GPM flow rate and 2400 PSI at a maximum flow rate of 2.3 GPM. This product is equipped with a Briggs & Stratton 121R02 single cylinder OHV engine, capable of 190 cc displacement. It runs on regular unleaded gasoline of a minimum 87 octane. Its pump is an Axial cam pump with a brass head. The high-pressure hose measures 20 feet in length and is made of steel-braided material.
The Craftsman 580.754920 pressure washer has several features including an engine that is ready for easy starting, without any need for priming or choking. It comes with a detergent siphon hose to apply cleaning solutions. The storage for the nozzle and accessories is conveniently located on board. The handle can be folded down to save space and the pneumatic tires and integrated handle make it portable. The product also includes a thermal relief system that cycles water to prevent the pump from overheating.
Technical Specifications
  • Model Number: 580.754920
  • Product Type: Gas-Powered Pressure Washer
  • Engine: Single cylinder OHV, 190 cc displacement
  • Fuel Type: Regular unleaded gasoline, minimum 87 octane
  • Oil Capacity: 20 oz, SAE 30 oil recommended
  • Pump Type: Axial cam pump, brass head
  • High Pressure Hose: 20 ft, steel braided
  • Spray Gun Type: Cushion grip with integrated nozzle storage and quick connect nozzle
  • Nozzles: 0°, 15°, 40° quick connect nozzles and detergent nozzle
  • Water Inlet: Garden hose (Female) connection
  • Dimensions: 17 x 17 x 34 in
  • Weight: 60 lbs
  • Additional Features: Detergent siphon hose, Onboard nozzle and accessory storage, Fold-down handle, Pneumatic tires and integrated handle, Thermal relief system
Warranty
The Craftsman 580.754920 Pressure Washer comes with a 2-year limited warranty which covers all parts and components. However, it doesn't extend to consumables such as nozzles, hoses, filters, and similar items. Additionally, the engine emissions system is covered separately by a 2-year warranty.
Craftsman 580.754920 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 25
All Time: 606
