2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.75491
Background
The Craftsman Pressure Washer 580.754910 is a gasoline-powered machine that uses a Honda GCV160LAON5BR 161cc engine. Its purpose is to output a high-pressure stream of water to clean various surfaces. It can produce pressure up to 2800 PSI and flow rate up to 2.3 GPM. The machine operates on gasoline with a fuel tank capacity of 0.29 gallons. Weighing approximately 60 lbs, it has a compact structure with dimensions of 17" x 19" x 34".
This pressure washer is equipped with a variety of features to make operation more convenient. It has a portable design with 10" wheels and a fold-down handle, making it easy to move around the cleaning site. It comes with a 25-foot high-pressure hose and detergent siphon hose for applying cleaning solutions. The machine includes four Quick Connect spray tips (0°, 15°, 40°, soap) to accommodate different cleaning needs. It also has an onboard storage for accessories and an automatic cool down system that cycles water to prevent overheating. The engine starts using a recoil and auto-start system.
Technical Specifications
  • Model Number: 580.754910
  • Type: Portable Gasoline-Powered Pressure Washer
  • Engine: Honda GCV160LAON5BR 161cc
  • Pump: Axial Cam Direct Drive Pump
  • Pressure: Maximum 2800 PSI
  • Flow Rate: Maximum 2.3 GPM
  • Power Source: Gasoline
  • Fuel Tank Capacity: 0.29 Gallons
  • Detergent System: Uses Detergent Siphon Hose
  • Weight: Approximately 60 lbs
  • Dimensions: 17" x 19" x 34"
Warranty
The Craftsman Pressure Washer 580.754910 is accompanied by a 2-year comprehensive warranty. This warranty covers any defects in the materials or workmanship from the date of purchase. It is important to note, however, that this warranty does not extend to expendable parts such as hoses, nozzles, and filters. In terms of the engine, it is covered separately by the engine manufacturer's warranty. In order to make a warranty claim, you should contact the manufacturer or your place of purchase, ensuring that you have your proof of purchase and the details of the defect at hand.
Craftsman 580.754910 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 20
All Time: 470
