7 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.75488
Background
The Craftsman 580.754880 is a pressure washer produced by Craftsman, a brand under Sears Brands. This gas-powered pressure washer is intended for medium-duty residential cleaning tasks. It operates at a maximum pressure of 3000 PSI and a maximum flow rate of 2.7 GPM, powered by a Briggs & Stratton 190cc OHV engine. The fuel type is unleaded gasoline with a minimum of 87 octane, and the fuel tank capacity is 1.6 quarts. The oil type recommended is SAE 30, API SF/SG/SH/SJ or higher, with an oil capacity of 20 oz. The pressure washer is fitted with a 25 ft high-pressure hose and weighs 69 lbs. Its dimensions are 17x17x28 inches.
This pressure washer includes several features designed to enhance its utility and ease of use. These include a durable tubular steel frame and 13-inch pneumatic tires for mobility, a 25 ft high-pressure hose with an ergonomic spray gun and wand, and five Quick Connect nozzles for various cleaning tasks. There is onboard storage for the spray gun, wand, nozzles, and other accessories, and a detergent siphon for applying cleaners from a concentrated bottle. The engine has a low-oil shutdown feature for safety. An automatic cool-down system cycles water to prevent the pump from overheating.
Technical Specifications
  • Model Number: 580.754880
  • Product Type: Pressure Washer
  • Maximum Pressure: 3000 PSI
  • Maximum Flow Rate: 2.7 GPM
  • Engine: 190cc OHV
  • Fuel Type: Unleaded gasoline, minimum 87 octane
  • Fuel Tank Capacity: 1.6 quarts
  • Oil Type: SAE 30, API SF/SG/SH/SJ or higher
  • Oil Capacity: 20 oz
  • High Pressure Hose Length: 25 ft
  • Weight: 69 lbs
  • Dimensions: 17 x 17 x 28 in
Warranty
The Craftsman Pressure Washer 580.754880 comes with a 2-year limited warranty provided by Sears. This warranty covers any defects in the materials and workmanship of the product. To claim the warranty, it's recommended that owners register their pressure washer and maintain records of any maintenance performed. In the event of a defect or malfunction, owners can seek replacement parts or services from Sears under this warranty.
Craftsman 580.754880 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 35
All Time: 627
