No Image
This wiki is missing a device image. Help improve this page by uploading one!
5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.753, 580.753000
Background
The Craftsman Pressure Washer 580.753000 is a gas-powered machine manufactured by Goldstar for Sears. This pressure washer is equipped with a 7.25 horsepower Briggs and Stratton engine and is capable of delivering a maximum of 3000 PSI at a flow rate of 2.7 GPM.
This pressure washer is designed to be used with a water supply that does not exceed a temperature of 100°F. The machine has a shipping weight of 75 pounds and is fitted with a long life platinum Champion RC12PYP or standard resistor Champion RC12YC spark plug, with a gap of 0.020 inches. The fuel capacity of this pressure washer is 3 quarts. Depending on the temperature, it requires SAE 30, SAE 5W-30 or 10W-30 oil.
The pressure washer is started by positioning it near an outdoor water source with a flow rate of at least 3.7 GPM, ensuring all hoses are securely connected, and following the designated start-up procedures outlined in the user manual. For detergent application, it is recommended to use a detergent specifically made for pressure washers. The machine should be maintained regularly, including changing the engine oil after the first 5 hours and every 50 hours thereafter, checking and cleaning the water inlet screen, inspecting the high pressure hose for wear or damage, and servicing the spark plug annually.
Technical Specifications
  • Model Number: 580.753000
  • Product Type: Pressure Washer
  • Pressure Output: 3000 PSI
  • Flow Rate: 2.7 GPM
  • Chemical Mix: As directed by chemical manufacturer
  • Max Water Supply Temperature: 100°F
  • Shipping Weight: 75 lbs
  • Engine: 7.25 HP Briggs and Stratton
  • Spark Plug: Champion RC12PYP or RC12YC, Gap 0.020 inches
  • Fuel Capacity: 3.0 quarts
  • Oil Type: SAE 30 above 40°F, SAE 5W-30 or 10W-30 between 0-40°F
  • Included Accessories: Base, handle, accessory tray, high pressure hose, spray gun, hose reel, turbo nozzle, nozzle extension with quick connect tips, oil bottle, owner's manual, registration card, and hardware kit.
Warranty
The Craftsman Pressure Washer 580.753000 comes with a one-year limited warranty for residential use, but this period reduces to 90 days for commercial use and further to 30 days if the washer is rented. This warranty covers defects in material and workmanship, offering protection against faults originating from the manufacturing process. However, it is important to note that any damage resulting from improper use, lack of maintenance, or freezing among other misuses is not covered by the warranty.
Craftsman 580.753000 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 31
All Time: 697
