No Image
This wiki is missing a device image. Help improve this page by uploading one!
5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.75301
Background
The Craftsman Pressure Washer 580.753010 is a cleaning device, known for its mechanic design and adaptability. Manufactured by Sears, it's a gas-powered pressure washer equipped with a 6 HP Honda GC190 engine. It's capable of producing up to 2800 PSI of pressure and has a flow rate of 2.2 gallons per minute, making it a suitable tool for a variety of cleaning tasks.
This pressure washer offers a set of features that enhance its usability and functionality. It includes two 0.5 gallon chemical tanks for the application of detergents or cleaners, and four Quick Connect spray tips for different spray patterns based on the cleaning task. It also has a 25-foot high pressure hose for extended reach and an onboard storage to keep nozzles and accessories organized. Additionally, it has an automatic cool down system to prevent overheating and pump damage, along with a brass pump head and thermal relief valve for durability. Its detergent injection system ensures that cleaners are applied with the low-pressure setting.
Technical Specifications
  • Model Number: 580.753010
  • Product Type: Pressure Washer
  • Engine: 6 HP Honda GC190, air-cooled 4-stroke OHV
  • Engine Displacement: 187cc
  • Fuel Tank Capacity: 0.53 gallons
  • Pump: Axial cam, brass head
  • Pressure: Up to 2800 PSI
  • Flow Rate: 2.2 gallons per minute
  • High Pressure Hose Length: 25 ft
  • Detergent Tank Capacity: Dual 0.5 gallon tanks
  • Power Cord Length: 35 ft
  • Dimensions: 17" x 17" x 34"
  • Weight: 73 lbs
Warranty
The Craftsman Pressure Washer 580.753010 comes with a limited warranty that varies depending on the usage. For residential use, the warranty coverage lasts for 1 year, for commercial use it is 90 days, and for rental use, it's 30 days. This warranty coverage is designed to protect against defects in materials and workmanship. Regular maintenance must be performed in order for the warranty to be valid. Furthermore, it is important to note that while the pump is covered for the entire warranty period, other components may have shorter coverage periods. To claim the warranty, it is typically required to reach out to the manufacturer, Sears in this case, with proof of purchase and details of the defect.
Craftsman 580.753010 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 339
