5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.75292, 580.752920
Background
The Craftsman 2700 PSI Pressure Washer, model number 580.752920, is a product designed for various cleaning applications. This pressure washer is fueled by gasoline and is equipped with a 163cc Briggs & Stratton engine. It has an axial cam pump that can generate a maximum pressure of 2700 PSI. The product also has a flow rate of up to 2.1 gallons per minute (GPM).
The product comes with four quick-connect spray tips that are suitable for different cleaning applications. It also includes a 25-foot high-pressure hose and a detergent siphoning system. The pressure washer is designed with a handle and an accessory tray for convenience, and it features 12-inch wheels that don't go flat. The product measures 17 x 17 x 34 inches and weighs 66 pounds.
Technical Specifications
  • Model Number: 580.752920
  • Product Type: Pressure Washer
  • Maximum pressure: 2700 PSI
  • Maximum flow rate: 2.1 GPM
  • Engine: 163cc Briggs & Stratton EXi OHV
  • Fuel tank capacity: 1.6 quarts
  • Pump: Axial cam pump
  • Power source: Gasoline
  • Dimensions: 17 x 17 x 34 in.
  • Weight: 66 lbs
  • Additional Features: Four quick-connect spray tips (0°, 15°, 40°, soap), 25 ft high pressure hose, detergent siphoning system, integrated handle and accessory tray, 12 in. never-flat wheels.
Warranty
The Craftsman 2700 PSI pressure washer, model 580.752920, comes with a 2-year limited warranty provided by Sears Brands. This warranty covers any defects in materials and workmanship for a period of two years from the date of purchase. However, it is important to note that the warranty does not cover parts that are subject to normal wear and tear, misuse, improper maintenance, or accidental damage. To claim the warranty, you can visit the Craftsman website at www.craftsman.com where you can find the full warranty details and instructions on how to proceed with your claim.
Craftsman 580.752920 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 44
All Time: 804
