4 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.75291
Background
The Craftsman 580.752910 is a pressure washer manufactured by GOLDSTAR for Sears under the Craftsman brand. It is powered by a 160 cc Honda GCV160 engine and includes an axial cam pump. This combination enables the pressure washer to generate up to 2600 PSI of water pressure and a flow rate of 2.3 GPM.
The pressure washer comes with a fuel tank that can hold up to 0.29 gallons of gasoline. It is designed to be portable and is fitted with 10" pneumatic tires for easy maneuvering. The unit includes a 20 ft high pressure hose and an on-board detergent injection system for added cleaning power. It also features a recoil start system for powering on the engine. The machine's compact dimensions (17 x 17 x 34 in) and weight (43 lbs) contribute to its portability.
Technical Specifications
  • Engine type: Honda GCV160 4-stroke gasoline engine
  • Engine displacement: 160 cc
  • Engine power output: 5.5 HP
  • Fuel tank capacity: 0.29 gallons
  • Pump type: Axial cam pump
  • Max pump pressure: Up to 2600 PSI
  • Water flow rate: Up to 2.3 GPM
  • High pressure hose length: 20 ft
  • Detergent system: On-board detergent injection system
  • Power source: Recoil start
  • Dimensions: 17 x 17 x 34 in
  • Weight: 43 lbs
Warranty
The Craftsman Pressure Washer 580.752910 comes with a 2-year limited warranty provided by Sears Brands Management Corporation. This warranty covers any defects in the materials or workmanship of the product. The emissions control system of the product, powered by Honda, is also under warranty for a period of 2 years. To claim the warranty, it would typically require you to reach out to Sears Brands Management Corporation or Honda, depending on the part of the product that needs attention. It's always a good idea to save your purchase receipt as it may be required as proof of purchase during the claim process.
Craftsman 580.752910 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 25
All Time: 471
