No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.7528
Background
The Craftsman 2800 PSI Pressure Washer, model number 580.752800, is a gas-powered device designed to deliver high-pressure water for cleaning purposes. Developed by Craftsman, this pressure washer is equipped with a 7 horsepower Briggs & Stratton engine that can produce a water flow rate of 2.8 gallons per minute at a pressure of 2800 PSI. The machine's dimensions are 24 x 19 x 40 inches, and it weighs 102 pounds.
The pressure washer is designed with a fuel tank capacity of 1.6 quarts and an axial cam pump. It also includes a 25-foot-long high-pressure hose. Additional features include three chemical tanks with a Dial-A-Cleaner selector, quick connect spray tips for varying degrees of spray patterns, an insulated spray gun with a safety lock, and an onboard hose reel. The pressure washer also includes a thermal relief system. For operation, the user must follow certain steps such as adding fuel and engine oil, connecting a garden hose to the water inlet, selecting and connecting the desired spray tip, starting the engine, and squeezing the spray gun trigger. The washer also has a Dial-A-Cleaner selector for switching between the three chemical tanks or water only.
Technical Specifications
  • Model Number: 580.752800
  • Product: Craftsman Pressure Washer 580.752800
  • Product Type: Pressure Washer
  • Pump Pressure: 2800 PSI
  • Water Flow Rate: 2.5 GPM
  • Engine: 7 HP Briggs & Stratton 286cc engine
  • Fuel Tank Capacity: 1.6 quarts
  • Power Source: Gasoline
  • Pump Type: Axial cam pump
  • High Pressure Hose Length: 25 ft
  • Dimensions: 24 x 19 x 40 in
  • Weight: 102 lbs
Warranty
The Craftsman 2800 PSI pressure washer (model 580.752800) comes with a 1-year limited warranty. This warranty covers the product against defects in material and workmanship. However, please note that commercial use of the product is covered for a shorter duration of 90 days. To claim the warranty, it is necessary to retain the purchase receipt as proof of purchase date, as it might be required to validate the warranty period. Should the product present defects during the warranty period, contact the manufacturer or an authorized dealer for guidance on how to proceed with the warranty claim.
Craftsman 580.752800 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 30
All Time: 622
