2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.75288
Background
The Craftsman Pressure Washer 580.752880 is a portable gas-powered cleaning device produced by Sears Brands. It utilizes a 177cc Briggs & Stratton overhead valve engine and an axial cam pump, which can generate up to 2700 PSI of water pressure, making it suitable for a variety of cleaning tasks.
This pressure washer includes multiple features such as a flow rate of 2.3 GPM, five quick connect spray tips, an onboard detergent tank, a 25 ft high-pressure hose, and a 35 ft onboard hose reel. Additionally, it has a fold-down handle for compact storage, two 12.5 oz onboard detergent tanks, and a Quick Switch detergent selector. The unit also includes a thermal relief system that automatically circulates water through the pump if temperatures reach 125-155°F, which helps to prevent pump damage.
The operation of the device involves connecting a garden hose to the water inlet, checking oil and fuel levels, connecting the high-pressure hose to the pump outlet and spray gun, selecting and connecting the desired spray tip, turning on the water supply and purging air from the system, starting the engine using the rocker switch and recoil starter, testing spray patterns, applying detergent using the soap spray tip, and rinsing with the desired high-pressure spray tip.
Maintenance includes checking the engine oil before each use and changing it after the first 5 hours of operation. The air filter should be cleaned every 50 hours or replaced yearly, and the spark plug should be replaced yearly. The pump oil level is maintenance-free, as the pump is pre-lubricated and sealed from the factory. The O-rings should be lubricated with grease during assembly to ensure proper sealing.
Technical Specifications
  • Model Number: 580.752880
  • Product Type: Pressure Washer
  • Manufacturer: Sears Brands
  • Engine: 177cc Briggs & Stratton overhead valve engine
  • Maximum Pressure: 2700 PSI
  • Flow Rate: 2.3 GPM
  • Pump Type: Axial cam pump
  • Spray Tips: 0°, 15°, 25°, 40°, soap (5 quick connect spray tips)
  • Detergent Tank: Onboard, two 12.5 oz tanks
  • High Pressure Hose Length: 25 ft
  • Hose Reel Length: 35 ft
  • Handle: Fold-down for compact storage
  • Detergent Selector: Quick Switch
  • Thermal Relief System: Included. Cycles water through the pump at 125-155°F to prevent pump damage.
Warranty
The Craftsman Pressure Washer 580.752880 comes with a 2-year full warranty provided by Sears Brands. This warranty covers any defects in materials and workmanship, however, it does not extend to normal wear parts or any damage resulting from improper use. To claim this warranty, it's typically necessary to contact Sears Brands directly, although the specific procedures may vary and should be detailed in the product manual.
Craftsman 580.752880 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 505
