2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.752872
Background
The Craftsman 580.752872 is a pressure washer model manufactured by Goldstar for Sears under the Craftsman brand. This portable, electric pressure washer is characterized by a maximum pressure rating of 2700 PSI and a maximum flow rate of 2.1 gallons per minute. The washer is powered by a Briggs & Stratton 111P02-0114-F1 175cc engine and utilizes an axial cam pump. It includes a 20 ft high pressure hose and an on-board detergent tank with a siphon tube. The pressure washer measures 17 x 17 x 34 inches and weighs 60 lbs.
The Craftsman 580.752872 pressure washer is intended for residential use and is suitable for cleaning vehicles, equipment, decks, driveways, and other surfaces. Its maximum pressure capacity effectively removes caked-on dirt and grime. The pressure washer comes with four quick connect spray tips (0°, 15°, 40°, soap), enabling users to adjust the spray pattern and pressure depending on the cleaning task. The operation involves attaching a garden hose for water supply, adding oil and fuel, and starting the engine with a manual recoil starter. The high-pressure water is directed using the high-pressure hose that connects to the spray gun. For cleaning solutions, detergent can be siphoned and mixed from the on-board tank.
Technical Specifications
  • Model Number: 580.752872
  • Product Type: Pressure Washer
  • Max Pressure: 2700 PSI
  • Max Flow Rate: 2.1 GPM
  • Power Source: 175cc engine
  • Pump Type: Axial cam pump
  • High Pressure Hose Length: 20 ft
  • Detergent Tank: On-board with siphon tube
  • Dimensions: 17 x 17 x 34 in
  • Weight: 60 lbs
  • Tire Type: Two 10" pneumatic tires with steel hubs
  • Valve Type: Thermal relief valve
Warranty
The Craftsman 580.752872 pressure washer comes with a 2-year limited warranty provided by Sears. This warranty covers any defects in materials or workmanship. Additionally, the emissions control system of the pressure washer has a separate 2-year warranty, which is mandated by the Environmental Protection Agency (EPA). However, it's important to note that the warranty does not cover commercial use, misuse, or improper maintenance of the product. The warranty claim can be initiated by contacting Sears customer service and providing the necessary details about the defect. Be prepared to provide proof of purchase, so it is recommended to keep all your receipts and documents handy.
Craftsman 580.752872 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 22
All Time: 519
