7 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.75283
Background
The Craftsman Pressure Washer 580.752830 is a gasoline-powered device designed for cleaning applications. This portable unit is equipped with a 163cc Briggs & Stratton engine, and it can deliver a maximum outlet pressure of 2,700 PSI with a maximum flow rate of 2.3 gallons per minute. The pressure washer has the ability to utilize detergents mixed with water, which should not exceed a temperature of 100°F.
The pressure washer comes with a range of features that enhance its functionality. These include a durable frame, three quick-connect nozzles for different cleaning tasks, a 25-foot high-pressure hose, and an onboard soap applicator for the application of cleaning solutions. It also includes a 12-inch surface cleaner suitable for cleaning large flat surfaces such as decks and driveways. Furthermore, the device comes with a 35-foot power cord and a fold-down handle for compact storage. The operation of the pressure washer involves checking levels of oil and fuel, selecting the appropriate nozzle, and starting the engine. It also includes the application of detergents in low pressure mode and requires regular maintenance.
Technical Specifications
  • Model Number: 580.752830
  • Product Type: Pressure Washer
  • Max Outlet Pressure: 2,700 PSI
  • Max Flow Rate: 2.3 GPM
  • Detergent Mix: Use as directed
  • Water Supply Temperature: Not to exceed 100°F
  • Engine: 163cc Briggs & Stratton 675 Series engine
  • Bore: 2.58 in (65.6 mm)
  • Stroke: 2.04 in (51.8 mm)
  • Displacement: 10.69 in3 (175 cc)
  • Spark plug: Briggs & Stratton 692051, gap 0.020 in (0.50 mm)
  • Armature air gap: 0.010-0.014 in (0.25-0.36 mm)
  • Fuel Tank Capacity: 1.6 Quarts
  • Oil Capacity: 20 Ounces (0.6 L)
  • Construction: Stainless steel
  • Engine Power: 6.5 HP
  • Nozzles: Three quick-connect nozzles (0°, 25°, 40°)
  • Pressure Hose: 25 ft high pressure hose with quick connects
  • Soap Applicator: Onboard soap applicator
  • Surface Cleaner Diameter: 12 inch
  • Power Cord: 35 ft power cord with GFCI
  • Handle: Fold-down handle
  • Storage: Built-in nozzle and cord wraps
Craftsman 580.752830 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 33
All Time: 589
