2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.75282
Background
The Craftsman Pressure Washer 580.752820 is a pressure washer designed for a variety of cleaning tasks. Manufactured by GOLDSTAR for Sears under the Craftsman brand, this washer is powered by a gasoline engine. It utilizes a 7 horsepower Briggs & Stratton engine, which in turn drives an axial cam pump. This pump is capable of producing a maximum pressure of 3000 PSI and a maximum flow rate of 2.7 GPM. The washer can use chemical mixes as directed and is designed to handle a maximum water supply temperature of 100°F.
In addition to these specifications, the Craftsman Pressure Washer 580.752820 includes several features for enhanced usability. It has three on-board detergent tanks with a Dial-A-Clean selector to adjust the amount of cleaning solution used. Additionally, it includes a hose reel for easy storage and a variety of ProjectPro nozzles for different cleaning requirements. It also comes with a HydroFoam launcher that makes applying detergents easier. An accessory tray is provided for further convenience.
Technical Specifications
  • Model Number: 580.752820
  • Product Type: Pressure Washer
  • Engine Type: Gasoline-powered 7 horsepower Briggs & Stratton engine
  • Maximum Pressure: 3000 PSI
  • Maximum Flow Rate: 2.7 GPM
  • Water Supply Temperature: up to 100°F
  • Shipping Weight: 74 lbs
  • Engine Specifications:
  • Gross Horsepower: 7 HP at 3600 RPM
  • Bore: 2.69 in (68 mm)
  • Stroke: 2.04 in (52 mm)
  • Displacement: 11.58 in3 (190 cc)
  • Spark Plug: Champion RC12PYP (Long Life Platinum) or Champion RC12YC (Standard Resistor)
  • Spark Plug Gap: 0.020 in (0.50 mm)
  • Valve Clearance (cold engine):
- Intake: 0.004-0.006 in (0.10-0.15 mm)
- Exhaust: 0.004-0.008 in (0.10-0.20 mm)
  • Fuel Capacity: 1.6 quarts
  • Oil Capacity: 22 oz
  • Pump Type: Axial cam pump with thermal relief system
  • Features:
  • Three on-board detergent tanks
  • Hose reel for storage
  • Different angle nozzles
  • Launcher for applying detergents
  • Accessory tray
Warranty
The Craftsman Pressure Washer 580.752820 comes with a warranty policy that varies depending on its usage. If used for residential purposes, the warranty coverage extends for a full year, covering any defects in material or workmanship. However, if the pressure washer is used for commercial or rental purposes, the warranty coverage is limited to 90 days. To claim the warranty, it is generally required to keep the purchase receipt and contact the manufacturer or the authorized service center detailing the issue faced.
Craftsman 580.752820 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 381
