2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.752722
Background
The Craftsman 2550 PSI Pressure Washer 580.752722 is a pressure washer model manufactured by Sears Brands. It is equipped with a 6.75 HP Briggs and Stratton engine, providing an output of up to 2.0 GPM at a maximum pressure of 2550 PSI. This makes it suitable for cleaning a variety of surfaces.
The pressure washer is built with three quick connect nozzles (0°, 15°, 40°), which allow users to switch between different spray patterns and pressure levels based on the cleaning task at hand. It also features two 1-quart detergent tanks with shut-off valves, which facilitates the application of different detergent solutions. The inclusion of a HydroFoam launcher allows users to apply detergents and create a foaming effect on surfaces. Additionally, the pressure washer includes an onboard hose reel, accessory tray, and tree clips for secure storage of nozzles, the gun, and the cord when not in use. It also has a thermal relief system that cools the pump automatically if it's left running for 3-5 minutes without triggering the spray gun.
Technical Specifications
  • Model Number: 580.752722
  • Product Type: Pressure Washer
  • Max Pressure: 2550 PSI
  • Max Flow Rate: 2.3 GPM
  • Water Supply Temperature: Not to exceed 100°F
  • Shipping Weight: 78 lbs
  • Engine Rated Horsepower: 6.75 HP at 3600 RPM
  • Engine Displacement: 190 cc
  • Fuel Capacity: 1.6 Quarts
  • Oil Capacity: 20 Ounces
  • Oil Type: SAE 30 above 40°F, SAE 5W-30 or 10W-30 below 40°F
  • Detergent Tanks: Two 1-quart tanks with shut-off valves
  • Nozzles: 3 quick connect nozzles (0°, 15°, 40°)
  • Storage: Onboard hose reel, accessory tray, and tree clips
  • Thermal Relief System: Yes, cools the pump if left running for 3-5 minutes without triggering the spray gun
Warranty
The Craftsman 2550 PSI Pressure Washer 580.752722 is backed by a 1-year full warranty. This warranty covers defects in the product's materials and workmanship. However, it is important to note that the warranty becomes void if the pressure washer is used for commercial or rental purposes. To claim the warranty, the owner typically needs to provide proof of purchase and contact the manufacturer or retailer where the product was originally bought. Specific instructions may vary, so it's advisable to check the user manual or the manufacturer's website for the most accurate information.
Craftsman 580.752722 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 36
All Time: 871
