4 Diagrams
Documents
Models
580.75271
Background
The Craftsman 2550 PSI Pressure Washer (Model 580.752710) is a machine that uses a gasoline-powered engine to drive a pump which pressurizes water from a hose, amplifying the force of the water for cleaning purposes. Manufactured by Sears, this pressure washer can generate up to 2550 PSI (pounds per square inch) of water pressure, with a flow rate of 2.3 GPM (gallons per minute).
The pressure washer utilizes a 190cc engine, an axial cam pump equipped with a thermal relief valve, and a chemical injection system that comes with two 32-ounce detergent tanks. Additionally, it has a 25-foot high-pressure hose and a ProjectPro spray gun that comes with four quick-connect nozzles. The machine also includes onboard storage for the spray gun and nozzles and is fitted with 10-inch wheels that never go flat, offering better maneuverability. The maintenance of the pressure washer involves regular service of the engine oil, pump oil, and air filter. The spark plug and combustion chamber require service every 100 hours or annually.
Technical Specifications
  • Model Number: 580.752710
  • Product Type: Pressure Washer
  • Engine: 190cc with 6.75 HP
  • Pump: Axial cam pump with thermal relief valve
  • Maximum pressure: 2550 PSI
  • Flow rate: 2.3 GPM
  • High pressure hose length: 25 ft
  • Detergent tank capacity: 2 x 32 oz
  • Fuel tank capacity: 1.6 gallons
  • Weight: 63 lbs
Warranty
The Craftsman Pressure Washer model 580.752710 comes with a limited warranty that lasts for one year, provided by Sears. This warranty is applicable from the date of purchase and covers any defects in the materials and workmanship of the product, but only for residential use. In cases of commercial use, the warranty period is shorter, lasting for 90 days. For rental use, the warranty is valid for 30 days. To claim the warranty, customers can likely reach out to Sears, as they are the provider of the warranty. However, the exact warranty claim process is not mentioned in the context and customers are advised to refer to the warranty section in the owner's manual or contact Sears for detailed instructions.
Craftsman 580.752710 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 22
All Time: 743
