No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.7526
Background
The Craftsman Pressure Washer 580.752600 is a machine designed for outdoor cleaning tasks. It is powered by a gas-operated, 7 horsepower Briggs & Stratton engine and is capable of delivering a pressure of 2600 PSI at a flow rate of 2.5 gallons per minute.
This pressure washer is equipped with several functional features. It includes a spray gun with a safety latch, an adjustable nozzle with both high and low pressure settings, a 25-foot high pressure hose, and a garden hose connector. Additionally, it features a detergent siphon tube for soap application and pneumatic tires for easy maneuverability. The pump of the washer is designed with a thermal relief system that cools it automatically if it runs for 3-5 minutes without the trigger being pulled. The adjustable nozzle allows for versatility in the spray pattern, offering options from a narrow jet to a 40-degree fan pattern. Regular maintenance, as detailed in the owner's manual, is recommended for the best performance of the washer.
Technical Specifications
  • Model Number: 580.752600
  • Product Type: Gas-powered Pressure Washer
  • Pressure Output: 2600 PSI
  • Flow Rate: 2.5 GPM
  • Max Water Supply Temperature: 100°F
  • Shipping Weight: 74 lbs
  • Engine: 7 HP Briggs & Stratton 12F612
  • Engine Fuel Capacity: 1.6 Quarts
  • Engine Oil Type: SAE 30 above 40°F, SAE 5W-30 or 10W-30 between 0°F-40°F
  • Engine Spark Plug: Champion RC12YC (standard), Champion RC12PYP (long life platinum)
  • Spark Plug Gap: 0.020 inches
  • Features: Spray gun with safety latch, Adjustable nozzle, 25 ft high pressure hose, Garden hose connector, Detergent siphon tube, Pneumatic tires
  • Cooling System: Anodized pump with thermal relief system
  • Nozzle Settings: Adjustable from narrow jet to 40° fan pattern
  • Detergent Application: Siphon tube draws detergent and mixes it with stream at low pressure
Craftsman 580.752600 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 46
All Time: 563
