No Image
This wiki is missing a device image. Help improve this page by uploading one!
5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.75255
Background
The Craftsman Pressure Washer 580.752550 is a gasoline-powered pressure washer designed by Craftsman and manufactured by Goldstar. Intended for residential use, it can be utilized for cleaning a variety of surfaces such as cars, boats, decks, and driveways. The pressure washer is equipped with a 6.5 HP Briggs & Stratton engine and an axial cam pump, capable of delivering a pressure of 2550 PSI at a flow rate of 2.5 GPM.
The pressure washer is characterized by its portability, owing to a steel frame with two wheels. It has an onboard detergent tank for easy application of soaps and cleaners, and an adjustable spray nozzle that allows for high and low pressure settings. The unit also includes an automatic cool-down system to prevent overheating. It is designed to be user-friendly in its maneuverability and operation. Maintenance considerations include the changing of engine and pump oil, and the regular inspection and cleaning of filters, hoses, pump, and nozzle.
Technical Specifications
  • Model Number: 580.752550
  • Product Type: Pressure Washer
  • Pressure: 2550 PSI
  • Flow Rate: 2.5 GPM
  • Fuel Tank Capacity: 3 quarts
  • Shipping Weight: 75 lbs
  • Engine: 6.5 HP Briggs & Stratton
  • Frame: Steel, with two wheels for portability
  • Pump Type: Axial cam
  • Hose Length: 25 ft
  • Spray Nozzle: Adjustable, with high and low pressure settings
  • Detergent Tank: Onboard
  • Cool-Down System: Automatic
  • Engine Oil Capacity: 20 oz
  • Pump Oil Capacity: 16 oz
  • Fuel Type: Unleaded gasoline
  • Maximum Water Inlet Temperature: 100°F
  • Maximum Water Inlet Pressure: 20 PSI
Warranty
The Craftsman 580.752550 pressure washer comes with a limited 1-year warranty for consumers. This warranty covers any defects that can be attributed to materials or workmanship, provided that the unit is used for non-commercial purposes. If the pressure washer is used for commercial or rental purposes, the warranty period shortens to 90 days and 30 days respectively. Please note, the warranty does not extend to consumable parts such as pumps, hoses, and nozzles. Also, any damage that results from improper use or insufficient maintenance is not covered by the warranty. To claim the warranty, you need to keep your purchase receipt as proof and contact the Craftsman customer service, who will guide you through the process.
Craftsman 580.752550 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 27
All Time: 418
