No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Documents
Models
580.75254
Background
The Craftsman 3100 PSI Pressure Washer 580.752540 is a portable, gasoline-powered device designed to aid in a variety of residential cleaning tasks. It is equipped with a 212cc Briggs & Stratton engine and an axial cam pump, which combined, can produce up to 3100 PSI of water pressure at a flow rate of 2.8 GPM. The pressure washer also includes a 1/2 gallon soap tank and a 25 ft steel-reinforced high pressure hose.
The Craftsman 3100 PSI Pressure Washer 580.752540 is used for cleaning a range of surfaces including cars, boats, patios, decks, and driveways. It comes with five quick-connect spray tips (0°, 15°, 25°, 40°, and soap) for tackling light to heavy-duty cleaning tasks. The device includes an integrated hose reel for organized storage of the hose and a pivoting spray wand for directing the spray at multiple angles. The pressure washer is gasoline-powered and has a durable steel frame construction.
Technical Specifications
  • Engine: 212cc Briggs & Stratton overhead valve engine
  • Displacement: 12.5 cu. in. (205cc)
  • Fuel capacity: 1.6 quarts
  • Oil capacity: 20 oz (0.6 liters)
  • Pump type: Axial cam pump
  • Max pressure: 3100 PSI
  • Max flow rate: 2.8 GPM
  • High pressure hose length: 25 ft
  • Soap tank capacity: 1/2 gallon
  • Power source: Gasoline
  • Weight: 57 lbs
Warranty
The Craftsman 3100 PSI Pressure Washer 580.752540 comes with a 2-year limited warranty. This warranty covers defects in materials and workmanship from the date of purchase for residential use. For commercial and rental use, a 90-day coverage is provided from the purchase date. However, certain exclusions apply to this warranty. Normal wear parts such as hoses, spray guns, nozzles, valves are not covered. Additionally, damages caused by improper use, maintenance, storage, or freezing conditions are also not covered by the warranty. The warranty for the engine is handled separately by its manufacturer. To claim the warranty, refer to the warranty guidelines provided by Craftsman, which typically involves contacting their customer service or authorized repair centers with proof of purchase and details of the defect.
Craftsman 580.752540 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 4
Past 7 Days: 6
Past 30 Days: 25
All Time: 542
