No Image
This wiki is missing a device image. Help improve this page by uploading one!
5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.752541
Background
The Craftsman 580.752541 is a pressure washer that operates on a gasoline-powered engine. It is made by Goldstar for Sears under the Craftsman brand. The primary features of the pressure washer include a 208 cc Briggs & Stratton engine and an axial cam pump. This pump is capable of producing an output of up to 3100 PSI, equivalent to 2.5 gallons per minute.
The pressure washer includes five quick connect spray tips, onboard hose and spray gun storage, and two detergent siphoning tubes. It is equipped with a 208 cc Briggs & Stratton OHV engine, a 4-stroke, overhead valve design with pressurized lubrication. The engine uses regular unleaded gasoline and has a fuel capacity of 1.6 quarts. The oil capacity is 20 oz. The dimensions of the pressure washer are 17 x 17 x 34 inches, and it weighs 75 lbs.
Technical Specifications
  • Model Number: 580.752541
  • Product Type: Pressure Washer
  • Maximum Pressure: 3100 PSI
  • Water Flow Rate: 2.5 GPM
  • Detergent Tank: Use external siphon
  • Engine: 208 cc Briggs & Stratton 121012 OHV
  • Engine Displacement: 208 cc
  • Power Source: Gasoline
  • Start Type: Recoil
  • Pump Type: Axial cam
  • Pump Materials: Brass/Stainless Steel
  • High Pressure Hose Length: 20 ft
  • Inlet Water Hose Compatibility: Standard garden hose
  • Dimensions: 17 x 17 x 34 in
  • Weight: 75 lbs
  • Engine Bore x Stroke: 2.67 inch x 2.2 inch
  • Fuel Capacity: 1.6 quarts
  • Oil Capacity: 20 oz.
Warranty
The Craftsman 580.752541 pressure washer comes with a 2-year limited warranty provided by Sears. This warranty specifically covers any defects that may arise from materials or workmanship. It's important to note that items subject to normal wear, such as hoses, spray guns, and nozzles are not included in this warranty. In case of issues with the engine, the warranty is provided by Briggs & Stratton. To claim the warranty, you would need to reach out to Sears or Briggs & Stratton, as applicable, with details of the defect or issue.
Craftsman 580.752541 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 28
All Time: 435
