No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.752541
Background
The Craftsman 580.752541 is a pressure washer manufactured for Sears under the Craftsman brand. It is gas-powered, utilizing a 208cc Briggs & Stratton engine. The pressure washer is capable of generating up to 3100 PSI of water pressure. It is designed to emit water at a flow rate of 2.5 gallons per minute. The fuel tank has a capacity of 1.6 gallons, and the unit is fitted with an axial cam pump. The pressure washer is equipped with a 25-foot high-pressure hose.
This pressure washer includes a set of five quick-connect spray nozzles with varying pressure settings. It has two detergent siphoning tubes designed for both concentrated and diluted mixtures. The washer also includes a tray for storing the nozzles and spray gun. For mobility, it is fitted with 12-inch semi-pneumatic wheels. There is also an automatic cool-down system designed to prevent the pump from overheating.
Technical Specifications
  • Maximum pressure: 3100 PSI
  • Water flow rate: 2.5 GPM
  • Power source: 208cc Briggs & Stratton engine
  • Fuel type: Unleaded gasoline
  • Fuel tank capacity: 1.6 gallons
  • Pump type: Axial cam pump
  • Power rating: 6.5 HP
  • High pressure hose length: 25 ft
  • Dimensions: 17 x 17 x 34 in
  • Weight: 83 lbs
Warranty
The Craftsman 580.752541 pressure washer comes with a 2-year limited warranty provided by the manufacturer, Sears Brands. This warranty is applicable from the date of purchase and covers any defects that may occur due to faulty materials or workmanship. However, it's important to note that wear parts such as spray nozzles, guns, and hoses are not included under this warranty coverage. The warranty is applicable only for residential use of the pressure washer, and any commercial usage would lead to the voiding of this warranty.
Craftsman 580.752541 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 29
All Time: 263
