2 Diagrams
Documents
Models
580.752532
Background
The Craftsman 3000 PSI Pressure Washer 580.752532 is a gas-operated device designed for residential cleaning applications. Manufactured by Craftsman, it utilizes a Briggs & Stratton 675 series engine, with an engine displacement of 163 cc. The pressure washer is capable of a maximum pressure of 3000 PSI and a maximum flow rate of 2.7 GPM. It uses regular unleaded gasoline as its fuel, with a fuel tank capacity of 1.6 quarts, and the axial cam pump has a power rating of 6.75 HP gross. The product's physical dimensions are 17 x 17 x 34 inches, and it weighs 75 lbs.
The pressure washer includes three quick-connect nozzle tips (0°, 25°, 40°) that have adjustable spray patterns, and a 25 ft high-pressure hose. It also features a fold-down handle for compact storage, two detergent siphoning tubes, onboard accessory storage, and 16 in. pneumatic tires. This pressure washer is designed for outdoor use and is useful for cleaning vehicles, decks, patios, garages, siding, and various other areas around a residence. The adjustable spray patterns allow a user to select the most suitable spray for each specific cleaning task.
Technical Specifications
  • Model Number: 580.752532
  • Product: Craftsman Pressure Washer
  • Maximum pressure: 3000 PSI
  • Maximum flow rate: 2.7 GPM
  • Power source: Gas-powered engine (Briggs & Stratton 675 series)
  • Engine displacement: 163 cc
  • Fuel type: Regular unleaded gasoline
  • Fuel tank capacity: 1.6 quarts
  • Pump type: Axial cam pump
  • Power rating: 6.75 HP gross
  • High pressure hose length: 25 ft
  • Dimensions: 17 x 17 x 34 in
  • Weight: 75 lbs
Warranty
The Craftsman 3000 PSI Pressure Washer 580.752532 comes with a 2-year limited warranty offered by Craftsman. This warranty covers any defects in the materials and workmanship of the product, providing protection against faults that arise from the manufacturing process. However, the warranty does not extend to normal wear items such as hoses, nozzles, and filters. It's also worth noting that the engine may be subject to a separate warranty covered by its respective manufacturer. To claim the warranty, you typically need to reach out to Craftsman's customer service with proof of purchase and details about the defect. Be sure to check the exact warranty claiming process from the manufacturer's documentation or website to ensure a smooth and swift resolution to your issue.
Craftsman 580.752532 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 4
Past 7 Days: 7
Past 30 Days: 36
All Time: 686
