1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.75252
Background
The Craftsman Pressure Washer 580.752520 is a pressure washer manufactured by Sears, Roebuck and Co., originally produced by GOLDSTAR. This gas-powered device is equipped with a 10.69 cubic inch (175cc) overhead valve engine from Briggs & Stratton, which allows it to produce a maximum pressure of 2700 PSI at a flow rate of 2.3 gallons per minute.
The device includes several features designed to enhance its functionality. It has a ReadyStart® engine, which aids in swift and uncomplicated starts. A 2-in-1 soap system facilitates the application of concentrated or diluted detergent. The device comes with five quick connect spray tips (0°, 15°, 25°, 40° and soap) for various cleaning tasks. A 25-foot high-pressure hose extends the washer's reach, and onboard storage helps keep nozzles and accessories organized. The Craftsman Pressure Washer 580.752520 also includes a number of maintenance procedures, such as checking and cleaning the water inlet screen, testing the spray gun and hose for leaks, and flushing the detergent siphon after use.
Technical Specifications
  • Engine: 10.69 cubic inch (175cc) Briggs & Stratton overhead valve
  • Pressure: Maximum 2700 PSI
  • Flow rate: Maximum 2.3 gallons per minute
  • High pressure hose length: 25 feet
  • Detergent usage: Compatible with siphon hose
  • Pump type: Axial cam
  • Power source: Gasoline
  • Fuel tank capacity: 1.6 quarts
  • Oil capacity: 20 oz (0.6 liters)
  • Weight: Approximately 60 lbs
Warranty
The Craftsman Pressure Washer 580.752520 comes with a 2-year limited warranty provided by Sears. This warranty coverage includes defects resulting from materials and workmanship, and it is valid from the date of purchase for residential use. It's important to note that some exclusions apply, particularly for commercial use and wear items. In addition, the engine warranty is handled separately by the engine manufacturer. To claim the warranty, customers should reach out to Sears with proof of purchase and details of the issue experienced.
Craftsman 580.752520 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 36
All Time: 877
