4 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.75251
Background
The Craftsman Pressure Washer 580.752510 is a pressure washer that operates on a gas-powered engine. Produced by Sears Brands and belonging to the Craftsman line, this product is equipped with a 9.8 cu in (161 cc) engine. This enables the pressure washer to produce a maximum pressure of 2600 PSI and a flow rate of 2.3 GPM.
The Craftsman Pressure Washer 580.752510 comes with several features including a 161 cc Craftsman engine, an automatic cool down system, and a Project Pro PerfectMix siphon designed for detergent application. It also includes a set of 5 quick connect nozzles, an accessory tray, a 25 ft high pressure hose, and a detergent siphon tube. For operation, the product requires connection to a garden hose, fresh unleaded gasoline, and the attachment of the high pressure hose to the pump and spray gun. Regular maintenance such as checking and cleaning the water inlet screen, high pressure hose, and debris buildup, as well as changing the engine oil and servicing the air cleaner, is recommended.
Technical Specifications
  • Maximum pressure: 2600 PSI
  • Maximum flow rate: 2.3 GPM
  • Engine displacement: 9.8 cu in (161 cc)
  • Spark plug gap: 0.028-0.031 in
  • Fuel capacity: 0.29 gallons
  • Maximum water supply temperature: 100°F
  • Hose length: 25 ft
Warranty
The Craftsman Pressure Washer 580.752510 comes with a 2-year limited warranty provided by Sears Brands Management Corporation. This warranty covers any defects in the material and workmanship of the product. However, it's important to note that expendable parts such as nozzles, hoses, and filters are not included in this warranty. To claim the warranty, contact Sears Brands Management Corporation with details about the defect and proof of purchase. Before contacting, make sure the issue is not due to misuse or normal wear and tear as these are not covered under the warranty.
Craftsman 580.752510 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 26
All Time: 582
