2 Diagrams
Documents
Models
580.752501
Background
The Craftsman 2500 PSI Pressure Washer 580.752501 is a residential pressure washer. This gasoline-powered unit is known for its ability to generate pressures up to 2500 PSI and a maximum flow rate of 2.3 gallons per minute, making it suitable for a variety of outdoor cleaning tasks. It relies on an 11.87 cubic inch Briggs & Stratton 126T02 4-stroke overhead valve air-cooled gasoline engine for power. The unit also includes a 25-foot high-pressure hose and a set of 4 quick-connect spray tips to accommodate different cleaning scenarios.
The pressure washer features an axial cam pump, which is responsible for generating the high water pressure. It is equipped with an integrated filter screen and an automatic cooldown system that cycles water through the pump when temperatures reach 125-155°F to prevent overheating. Additional components include an onboard detergent tank for easy soap application and 10-inch never-flat wheels for enhanced mobility. The fold-down handle offers convenience in terms of storage.
Technical Specifications
  • Model Number: 580.752501
  • Product Type: Pressure Washer
  • Maximum pressure: 2500 PSI
  • Maximum flow rate: 2.3 gallons per minute (GPM)
  • Power source: 11.87 in3 (190 cc) 4-stroke overhead valve air-cooled gasoline engine
  • Fuel type: Unleaded gasoline, minimum 87 octane
  • Fuel tank capacity: 1.6 quarts
  • Oil type: SAE 30 oil, 18 oz capacity
  • High pressure hose length: 25 ft
  • Water supply requirement: Minimum 3.3 GPM at 20 PSI
  • Dimensions: approx 24 x 19 x 40 in
  • Weight: approx 60 lb
  • Pump type: Axial cam pump with brass head
  • Engine power rating: 6.5 HP
  • Engine features: Recoil start, fuel shut-off, automatic low oil shutoff
  • Accessories: 25 ft steel-braided high pressure hose, insulated spray gun with safety lock, 4 quick-connect spray tips (0°, 15°, 40°, soap), onboard soap tank, and 10 in. never-flat wheels.
Warranty
The Craftsman 2500 PSI Pressure Washer 580.752501 comes with a 2-year limited warranty provided by Sears Brands. This warranty covers any defects in materials and workmanship from the date of purchase for a duration of 2 years. However, it is important to note that the warranty does not cover certain components such as pump valves, seals and o-rings, which are considered consumable parts. To claim the warranty, it's generally recommended that you keep your original receipt as proof of purchase and contact Sears Brands directly should any issues arise within the warranty period.
Craftsman 580.752501 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 30
All Time: 573
