No Image
This wiki is missing a device image. Help improve this page by uploading one!
5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.7524
Background
The Craftsman 2800 PSI Pressure Washer 580.752400 is a gas-powered tool designed for medium-duty residential cleaning tasks. This pressure washer, manufactured by Craftsman, is equipped with a 7 HP Briggs and Stratton engine which can deliver a flow rate of up to 2.8 gallons per minute at a pressure of 2800 PSI.
The device has a fuel tank with a capacity of 1.6 quarts and an axial cam pump. It also comes with a 25-foot steel-braided high pressure hose that connects to a spray gun with an adjustable nozzle. The pressure washer allows for different spray patterns—from a narrow jet to a fan pattern—and has a switch for high and low pressure. Furthermore, it features a detergent siphon tube for applying detergents. Other attributes of the pressure washer include pneumatic tires, a metal wheel axle, and an integrated handle, hose reel, and nozzle storage.
Technical Specifications
  • Model Number: 580.752400
  • Product Type: Pressure Washer
  • Engine: 7 HP Briggs and Stratton single cylinder
  • Displacement: 190 cc
  • Fuel Tank Capacity: 1.6 quarts
  • Pump: Axial cam pump
  • Pressure: 2800 PSI
  • Flow Rate: 2.5 GPM
  • High Pressure Hose Length: 25 ft
  • Detergent Mixing: Via detergent siphon tube
  • Net Weight: 74 lbs
Warranty
The Craftsman 2800 PSI Pressure Washer 580.752400 comes with a limited warranty that lasts for one year from the date of purchase when used for residential purposes. However, the warranty duration is shorter for commercial or rental use, being limited to 90 days and 30 days respectively. The warranty provides coverage for defects in materials and workmanship, but it does not cover damage resulting from improper use, accidents, lack of maintenance, or normal wear and tear. Furthermore, fuel system parts, filters, spark plugs, and other consumable parts are not covered by the warranty. The engine itself is subject to a separate emission control warranty as required by the Environmental Protection Agency (EPA) and California Air Resources Board (CARB).
Craftsman 580.752400 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 45
All Time: 511
