No Image
This wiki is missing a device image. Help improve this page by uploading one!
5 Diagrams
Documents
Models
580.75241
Background
The Craftsman Pressure Washer 580.752410 is a gas-powered device designed to release water under high pressure. Manufactured by Sears Brands, LLC, it is equipped with a 7 HP Briggs & Stratton engine. This engine can produce a maximum output of 2,900 PSI at 2.3 GPM, making it suitable for a variety of cleaning tasks.
This pressure washer is designed for residential use and is categorized as a medium-duty machine. It comes with components including a 25 ft high-pressure hose, a spray gun, and four quick-connect nozzle tips, which are suitable for different types of cleaning. The device also incorporates a detergent tank, allowing the user to apply cleaning solutions as needed. Other notable features include 10" pneumatic tires for easy movement and an automatic cool-down system. The machine requires regular maintenance as outlined in the owner's manual to ensure optimal performance and longevity.
Technical Specifications
  • Model Number: 580.752410
  • Product Type: Pressure Washer
  • Engine: 7 HP Briggs & Stratton
  • Maximum Pressure: 2,900 PSI
  • Maximum Flow Rate: 2.3 GPM
  • Bore: 2.69 in (68 mm)
  • Stroke: 2.04 in (52 mm)
  • Displacement: 190 cc
  • Spark Plug (Long Life Platinum): Champion RC12PYP
  • Spark Plug (Resistor): Champion RC12YC
  • Spark Plug Gap: 0.020 in (0.50 mm)
  • Valve Clearance (Intake): 0.004-0.006 in (0.10-0.15 mm)
  • Valve Clearance (Exhaust): 0.004-0.008 in (0.10-0.20 mm)
  • Fuel Capacity: 1.6 Quarts
  • Oil Capacity: 22 Ounces
  • Oil Type: SAE 30 above 40°F, SAE 5W-30 or 10W-30 below 40°F
  • Shipping Weight: 74 lbs
  • Tire Size: 10" pneumatic tires
  • High Pressure Hose Length: 25 ft
  • Nozzle Tips: 4 quick-connect nozzle tips (0°, 15°, 40° and soap)
Warranty
The Craftsman Pressure Washer 580.752410 comes with a limited warranty that covers defects in materials and workmanship for a duration of one year from the date of purchase for residential use. For commercial and rental use, the warranty coverage is for 90 days and 30 days respectively. This warranty does not extend to expendable parts such as spark plugs or air filters that are subject to normal wear and tear. Additionally, any damage caused by improper use, negligence, or lack of maintenance, or the use of non-approved parts or accessories is not covered under the warranty. To claim the warranty, you need to return the unit to the nearest Sears service center. For full warranty details, Sears should be contacted.
Craftsman 580.752410 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 56
All Time: 726
