No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.7523
Background
The Craftsman Pressure Washer 580.752300 is a pressure washer that uses gasoline as its fuel source. It's a product of Sears, Roebuck and Co., under the Craftsman brand. The unit is powered by a 6.0 horsepower Briggs & Stratton engine, allowing it to generate a pressure of up to 2,300 PSI with a flow rate of 2.0 GPM.
The Craftsman 580.752300 uses an adjustable nozzle, enabling the user to switch between a narrow stream and a fan pattern. It comes with a brass head pump furnished with a thermal relief system to mitigate overheating. The washer incorporates a detergent injection system, which pulls soap from a separate container and combines it with the spray, enhancing the cleaning process. The pressure washer has a 25-foot high-pressure hose and an oil-filled crankcase that requires servicing every 50 hours or annually.
Technical Specifications
  • Model Number: 580.752300
  • Product Type: Pressure Washer
  • Engine: 6.0 HP Briggs & Stratton 12Q802
  • Pressure Output: Up to 2,300 PSI
  • Flow Rate: 2.0 GPM
  • Fuel Tank Capacity: 1.6 quarts
  • Oil Type: SAE 30 above 40°F, SAE 5W-30 or 10W-30 0°F to 40°F
  • Weight: 63 lbs
  • Pressure Nozzle: Adjustable, can spray in a narrow stream or fan pattern
  • Pump: Brass head with a thermal relief system
  • Detergent Injection System: Yes
  • High Pressure Hose Length: 25 feet
  • Pump Maintenance: Service every 50 hours or annually
Warranty
The Craftsman Pressure Washer 580.752300 is provided with a 1 year limited warranty. This warranty primarily covers any defects in materials and workmanship. However, it's worth noting that the warranty coverage for the pump is specific to the type of use: 1 year for residential use, 90 days for commercial use, and 30 days for rental use. Normal wear items such as hoses, filters, and nozzles are not included in the warranty coverage.
Craftsman 580.752300 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 47
All Time: 764
