2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.752381
Background
The Craftsman 3800 PSI Pressure Washer 580.752381 is a gas-operated pressure washer, made by Craftsman. This machine utilizes a 13 HP Honda GX390 engine and an axial cam pump. The pump is able to generate up to 3800 PSI at a rate of 4.0 gallons per minute (GPM).
The engine of the Craftsman 3800 PSI Pressure Washer 580.752381 has a displacement of 389 cc and operates at a rated horsepower of 13 HP at 3600 RPM. The fuel capacity for this engine is 1.72 gallons and it uses SAE 10W-30 type oil. The machine comes equipped with a 25 ft high-pressure hose and five quick-connect spray tips. These can be adjusted to different spray angles (0°, 15°, 25°, 40°) including a detergent tip. The pressure washer also has large pneumatic tires and a metal wheel axle, with an integrated handle and wand holder for convenience.
Technical Specifications
  • Model Number: 580.752381
  • Product Type: Pressure Washer
  • Engine: Honda GX390UT1
  • Pressure: 3800 PSI
  • Flow Rate: 4.0 GPM
  • Detergent Mix: Use as directed
  • Water Supply Temperature: Not to exceed 100°F
  • Pump Oil Capacity: 12 fl. oz. (0.35 L)
  • Rated Horsepower: 13 HP at 3600 RPM
  • Displacement: 389 cc
  • Bore x Stroke: 88 mm x 64 mm
  • Spark Plug: NGK BPR6ES, gap 0.028-0.031 in (0.7-0.8 mm)
  • Fuel Capacity: 1.72 Gallons
  • Oil Type: SAE 10W-30
  • Included Accessories: Five quick-connect spray tips (0°, 15°, 25°, 40° and detergent), 25 ft high pressure hose, insulated spray gun with safety lock
  • Physical Features: Large pneumatic tires and metal wheel axle, integrated handle and wand holder
Warranty
The Craftsman 3800 PSI Pressure Washer 580.752381 comes with a 2-year limited warranty, provided directly by Craftsman. This warranty specifically covers defects in materials and workmanship. It's important to note that normal wear items such as hoses, spray guns, and nozzles are not included in this warranty. The engine has a separate warranty provided by Honda. To claim the warranty, you should directly contact Craftsman or Honda for the engine-related issues.
Craftsman 580.752381 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 50
All Time: 1,110
