5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.75237
Background
The Craftsman Pressure Washer 580.752370 is a gasoline-powered machine, designed to facilitate medium-duty residential cleaning tasks. It operates on a 7 horsepower Briggs & Stratton engine and utilizes an axial cam pump, capable of delivering a water flow rate of up to 2.5 gallons per minute at a pressure of 2800 PSI. The machine's design incorporates a thermal relief system to help prevent overheating and subsequent damage to the pump.
The pressure washer is equipped with an onboard detergent tank and a siphon feed detergent injection system. It comes with five distinct quick connect spray tips for varying cleaning tasks. It also features an accessory tray and hose hook for organization, and pneumatic tires coupled with an integrated handle for ease of mobility. Regular maintenance, including checking and changing the pump and engine oil, cleaning the pump inlet filter screen, and storing the unit properly during off-seasons, can help ensure its longevity and effectiveness.
Technical Specifications
  • Model Number: 580.752370
  • Product: Craftsman Pressure Washer
  • Engine: 7 HP Briggs & Stratton overhead valve engine, 190cc displacement
  • Pump: Axial cam pump with thermal relief valve
  • Pressure: Up to 2800 PSI
  • Flow Rate: Up to 2.5 GPM
  • High Pressure Hose Length: 25 ft
  • Detergent System: Onboard detergent injection system
  • Power Source: Gasoline
  • Weight: 74 lbs
Warranty
The Craftsman 2800 PSI Pressure Washer 580.752370 comes with a warranty that lasts for 1 year. This warranty covers defects in both materials and workmanship. However, it's important to note that consumable parts such as pumps, seals, and O-rings are not covered under this warranty. The warranty for the engine is handled separately by Briggs & Stratton. If you need to claim the warranty, you would need to contact Craftsman or Briggs & Stratton, depending on whether the issue is with the general pressure washer or the engine specifically.
Craftsman 580.752370 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 26
All Time: 350
