4 Diagrams
Documents
Models
580.752352
Background
The Craftsman Pressure Washer 580.752352 is a gasoline-powered machine that is used for cleaning a variety of outdoor surfaces. Manufactured by Goldstar for Sears under the Craftsman brand, this device utilizes a 190cc Briggs & Stratton engine that can generate 6.0 gross horsepower at 3600 RPM. This enables the pressure washer to deliver a maximum outlet pressure of 2500 PSI at a flow rate of 2.3 GPM.
This pressure washer is equipped with a 30-foot high-pressure hose, spray gun, and three quick-connect nozzles, designed for different kinds of cleaning tasks. The main components of the washer are mounted on a steel frame with 10" pneumatic tires, allowing for easy transportation even on uneven terrains. It also features an accessory tray for storing nozzles and other accessories. The engine of this pressure washer has a fuel tank capacity of 1.6 quarts and a separate 1-gallon detergent tank which includes an adjustable soap mixing valve.
Technical Specifications
  • Model Number: 580.752352
  • Product Type: Pressure Washer
  • Manufacturer: Sears, Roebuck and Co.
  • Engine: Briggs & Stratton 190cc
  • Horsepower: 6.0 HP at 3600 RPM
  • Maximum Outlet Pressure: 2500 PSI
  • Maximum Flow Rate: 2.3 GPM
  • Water Supply Temperature Limit: 100°F
  • Shipping Weight: 63 lbs
  • Engine Bore: 2.69 inches (68mm)
  • Engine Stroke: 2.04 inches (52mm)
  • Engine Displacement: 11.57 cubic inches (190cc)
  • Spark Plug Type: Briggs & Stratton 802592 or 5095D, gap 0.030 inches
  • Hose Length: 30 feet
  • Nozzle Types: 0°, 15°, 40°
  • Frame: Steel frame with 10" pneumatic tires
  • Fuel Tank Capacity: 1.6 quarts
  • Detergent Tank Capacity: 1 gallon
  • Soap Mixing: Adjustable valve
Warranty
The Craftsman Pressure Washer 580.752352 is provided with a 1-year full warranty that covers any defects in materials and workmanship. This warranty also extends to normal wear items such as valves and seals, but only for a duration of 90 days from the date of purchase. Additionally, the emissions control system of the pressure washer is covered for a period of 2 years in accordance with EPA and CARB regulations. To claim the warranty, you should adhere to the regular maintenance schedule as outlined in the operator's manual. If defects or problems arise within the respective warranty periods, contact the manufacturer or the authorized service provider to initiate the warranty claim process.
Craftsman 580.752352 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 32
All Time: 625
