4 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.75234
Background
The Craftsman Pressure Washer 580.752340 is a gas-powered device designed for cleaning various outdoor surfaces. It is powered by a 4.5 horsepower Briggs & Stratton engine and is capable of generating up to 2200 PSI of water pressure. The flow rate of the unit can reach up to 2.2 GPM. The unit includes an onboard detergent tank for the application of cleaning chemicals, which are mixed with the pressurized water through the detergent injection system.
This pressure washer is equipped with four quick-connect spray nozzles, allowing the user to switch between different spray patterns according to the cleaning task at hand. It also features an accessory tray for convenient storage of nozzles and other tools. The metal wand and spray gun are connected to a 25-foot steel-wire braid high-pressure hose. The device is designed for portability, with 10" pneumatic tires and a wheeled design. Regular maintenance tasks for this unit include checking and cleaning the water inlet screen, high pressure hose, detergent siphon, and filters, as well as servicing the spark plug and keeping the engine cooling system free of debris.
Technical Specifications
  • Model Number: 580.752340
  • Product Type: Pressure Washer
  • Maximum Pressure: 2200 PSI
  • Maximum Flow Rate: 2.2 GPM
  • Engine: 4.5 HP Briggs & Stratton 10H902
  • Engine Displacement: 158cc
  • Fuel Capacity: 1 quart
  • Oil Capacity: 20 oz
  • Spark Plug: Champion RJ19LM or equivalent, gap 0.030 in
  • Shipping Weight: 63 lbs
  • Detergent Mix: Use as directed
  • Maximum Water Supply Temperature: Not to exceed 100°F
  • Included Accessories: Four quick connect spray nozzles (0°, 15°, 40° and soap), metal wand and spray gun, 25 foot steel-wire braid high pressure hose, accessory tray
  • Detergent Tank: Onboard
  • Portability: 10" pneumatic tires
  • Pump Type: Axial cam pump
  • Start Type: Electric start
Warranty
The Craftsman Pressure Washer 580.752340 comes with a limited 1-year warranty from the date of purchase for residential usage. For commercial or rental use, the warranty period is reduced to 90 days. This warranty covers any defects in materials or workmanship but does not extend to damage caused by improper use, lack of maintenance, freezing, or standard wear and tear. To maintain the warranty coverage, the product must be maintained according to the preventative maintenance procedures outlined in the operator's manual.
Craftsman 580.752340 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 33
All Time: 639
