2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.752342
Background
The Craftsman Pressure Washer 580.752342 is a gasoline-powered cleaning device, manufactured by GOLDSTAR for Sears under the Craftsman brand. Its primary function is to remove dirt, grime, mold, and other unwanted substances from various surfaces. This pressure washer is equipped with a 158 cc Briggs & Stratton engine that generates up to 2200 PSI of pressure. It is a portable unit, courtesy of its two-wheel and handle design, making it convenient for cleaning tasks around a home or work site.
The pressure washer features four Quick Connect nozzles for varying cleaning tasks. It has an external detergent injection system for cleaning solutions, and a 25-foot steel-reinforced high-pressure hose that accounts for extended reach. It also includes an inlet screen and in-line filter for pump protection, and an automatic cool-down system that cycles water to prevent overheating. The pump itself is pre-lubricated and sealed, requiring no additional maintenance.
Technical Specifications
  • Engine: 158 cc Briggs & Stratton EXi OHV
  • Displacement: 9.67 cu. in.
  • Horsepower: 4.5 HP
  • Fuel tank capacity: 1 qt
  • Pump: Axial cam
  • Maximum pressure: 2200 PSI
  • Maximum flow rate: 2.2 GPM
  • Power source: Pull start
  • Pump lubrication: Pre-lubricated and sealed
  • Detergent tank: External detergent injection
  • High pressure hose: 25 ft
  • Cord: None, gasoline powered
  • Weight: 63 lbs
Warranty
The Craftsman Pressure Washer 580.752342 comes with a 1-year warranty that covers any defects in materials and workmanship. However, limitations might apply if the product is being used for commercial purposes. Alongside this, there is a separate 2-year warranty specifically for the emissions control system. The warranty claims process was not explicitly mentioned in the provided text. Thus, it is recommended to refer to the product's user manual or the Craftsman company's official website for accurate guidance on how to claim the warranty.
Craftsman 580.752342 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 27
All Time: 406
