4 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.75222
Background
The Craftsman 2700 PSI Pressure Washer, model number 580.752220, is a gasoline-powered device designed for cleaning various surfaces. The product is equipped with a 190 cc Briggs & Stratton engine and an axial cam pump that enables a water flow of 2.3 gallons per minute and a pressure output of up to 2700 PSI.
The product is fueled by regular unleaded gasoline with a minimum octane rating of 87 and has a fuel capacity of 1.6 quarts. It also has an oil capacity of 22 ounces. The pressure washer can be started either using a recoil method or a 12V electric start. The product measures 17" x 19" x 34" and weighs 71 lbs. It also includes an adjustable nozzle system with different angles and a siphon detergent injection system. Furthermore, it has a thermal relief system to prevent pump damage and a fold-down handle for compact storage.
Technical Specifications
  • Product Type: Pressure Washer
  • Model Number: 580.752220
  • Engine: 190 cc Briggs & Stratton EXi OHV
  • Displacement: 190 cc
  • Fuel: Regular unleaded gasoline, 87 octane minimum
  • Fuel Capacity: 1.6 quarts
  • Oil Capacity: 22 ounces
  • Maximum Pressure: 2700 PSI
  • Maximum Flow: 2.3 GPM
  • Pump: Axial cam pump
  • Power Source: Recoil start and 12V electric start
  • Dimensions: 17" x 19" x 34"
  • Weight: 71 lbs
Warranty
The Craftsman 2700 PSI Pressure Washer, model 580.752220, comes with a limited warranty that lasts for a period of 1 year. This warranty, provided through Sears, covers any defects in the materials and workmanship of the pressure washer. Additionally, the engine of the pressure washer has a separate warranty provided by the manufacturer, which lasts for 2 years. To claim these warranties, defects must be within the stipulated time frame and fall under the conditions stated.
Craftsman 580.752220 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 22
All Time: 393
