9 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
580.752212
Background
The Craftsman 3000 PSI Pressure Washer 580.752212 is a gas-powered pressure washer. It's equipped with a 190cc Briggs & Stratton engine and an axial cam pump. This combination allows it to generate a pressure of up to 3000 PSI with a flow rate of 2.7 GPM. The pressure washer uses regular unleaded gasoline, with a minimum octane rating of 87, and has a fuel tank capacity of 1.6 quarts.
The pressure washer is designed with an aluminum head and brass manifold pump, and includes a 25-foot high-pressure hose for extended reach. It also includes five quick connect spray tips and a soap siphon hose. It has a weight of 77 lbs and dimensions of 24 x 24 x 24 inches. The machine is intended for various cleaning tasks, such as removing dirt from surfaces or washing vehicles. It has an onboard hose and accessory storage for organization and an insulated ergonomic spray gun.
Technical Specifications
  • Maximum pressure: 3000 PSI
  • Maximum flow rate: 2.7 GPM
  • Power source: 190cc Briggs & Stratton EXi OHV engine
  • Fuel type: Regular unleaded gasoline, 87 octane minimum
  • Fuel tank capacity: 1.6 quarts
  • Engine oil type: SAE 30 HD detergent oil
  • Engine oil capacity: 20 oz
  • High pressure hose length: 25 ft
  • Power cord: N/A (gas powered)
  • Weight: 77 lbs
  • Dimensions: 24 x 24 x 24 in
  • Pump type: Axial cam pump
  • Pump materials: Aluminum head, brass manifold
  • Included accessories: 5 Quick Connect spray tips, soap siphon hose, 25 ft high pressure hose, spray gun
Warranty
The Craftsman 3000 PSI Pressure Washer 580.752212 comes with a 2-year limited warranty for consumer use. This warranty also applies to the pump and frame for commercial use, while the engine has a separate 2-year commercial warranty. The warranty only covers defects in materials and workmanship. However, wear parts such as hoses, spray guns, and nozzles are not included in this coverage. It's important to note that the warranty will be void if the product is misused, improperly maintained, or damaged. To claim the warranty, you will typically need to provide proof of purchase and contact Craftsman's customer service for further instructions on the warranty claim process.
Craftsman 580.752212 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 921
